double cab rear door won't open from inside or outside
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andrewtheadventurer, Jan 28, 2019.
  1. Jan 28, 2019 at 7:38 AM
    andrewtheadventurer
    andrewtheadventurer [OP] Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Hey guys,
    I pulled my driver side rear door handle yesterday and something shifted inside the door and now the door wont open from the inside or outside. I suspect the cable inside the door has jumped out of the guide.
    Any ideas on how I can open the door without breaking things? Can I go through the window?
    Below is a picture of the inside of the door with the inside panel removed.
  2. Jan 28, 2019 at 2:02 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Peel off the plastic and look inside the door by the handle. It's likely the rod that may have became disconnected from the handle and connects to the actuator. For guidance, you could also pull the other side door panel off.
  3. Jan 30, 2019 at 6:10 PM
    wink4x4
    wink4x4 Well-Known Member
    Kentucky
    2017 DCSB TRD Offroad
    I just had this happen on my 3rd gen. @andrewtheadventurer , how did you get the door open with both handles not working?
  4. Jan 30, 2019 at 6:15 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Check the child lock switch to at least account for the interior handle not working. I had that happen when I pulled the handle to vinyl wrap the truck.
