Double Cab Rear Seat Non Slip matting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SnuggleTruck, May 2, 2023.
  1. May 2, 2023 at 8:12 AM
    SnuggleTruck
    SnuggleTruck [OP] Well-Known Member
    Alex
    Fort Myers
    2020 DCLB TRD OR
    TRD 2" lift shocks Icon AAL (gave me 1" lift with OL leaf out) 17x8.5" -12mm Trail Edition OEM replica wheels by FSW BF Goodrich KO2s (285 70 17) ECGS bushing OME carrier bearing drop kit TRD Pro skid plate Truxedo roll up Tonneau cover MESO - led interior light kit, blackout kit and gashole Toyota door sill protectors and bed mat
    Hey TW! I've been looking for and cant find a mat/cover that fits on the back of the rear double cab seats. That plastic surface area is nice when the seats are folded down but it is very slippery causing anything sitting there to fly all over the place (dogs, groceries, gear, wife, etc). :)
    Has anyone found a purpose built non slip cover for this area or something that fits the bill and is clean looking?
    Thanks as always!
  2. May 2, 2023 at 4:07 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Consider thin adhesive-backed memory foam sheets if you can live with something that's kinda permanent.
    Try: https://www.mcmaster.com/86195K11/ (green is least compressible). The color might not suit you though unless you're more concerned about function rather than looks.
    It's easy to cut with poultry shears.
    Worked for my 2-drawer toolbox except during extreme stops or moves. Too much mass.
  3. May 2, 2023 at 4:50 PM
    SnuggleTruck
    Alex
    Fort Myers
    2020 DCLB TRD OR
    That’s a good idea for a DIY solution… I’d need to find something in black though… no way I could rock one of those colors. Haha.
    Thanks for the idea!
  4. May 2, 2023 at 4:55 PM
    Friend of Crows
    Friend of Crows Well-Known Member
    2022 Tacoma SR
    Painted steelies black
    Outdoor carpet cut to size will work good with some double sided tape or carpet tape. I use it on my bed, holds things still surprisingly well. Cost me about $8 at Home Depot.
    SnuggleTruck[OP] likes this.
  5. May 2, 2023 at 5:01 PM
    SnuggleTruck
    Alex
    Fort Myers
    2020 DCLB TRD OR
  6. May 2, 2023 at 7:04 PM
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
  7. May 2, 2023 at 7:24 PM
    SnuggleTruck
    Alex
    Fort Myers
    2020 DCLB TRD OR
    That is exactly what I was looking for. Perfect!
  8. May 2, 2023 at 7:49 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I saved this picture awhile ago, pretty sure its EVA foam used on boat decks.
    BTL Y-Wing and SnuggleTruck[OP] like this.
  9. May 2, 2023 at 10:01 PM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    Damn good job on the cutting!
  10. May 3, 2023 at 4:27 AM
    SnuggleTruck
    Alex
    Fort Myers
    2020 DCLB TRD OR
    Right? I’m trying to figure out how I’m going to do a job that good! Lol
  11. May 3, 2023 at 5:14 AM
    SnuggleTruck
    Alex
    Fort Myers
    2020 DCLB TRD OR
    how in the hell did you cut the material this exact?!?
  12. May 3, 2023 at 8:00 AM
    CT Yankee
    CT
    Simple IMO. Make a paper or cardboard template to trace onto the material you're going to use.
    BTL Y-Wing likes this.
  13. May 3, 2023 at 12:50 PM
    BTL Y-Wing
    It's rougher up close, especially on the corners since I just used an exacto knife for it all. I traced out lines for the edges of the seat back on the rubber roll that went wide of the actual lines, then I kept trimming narrow strips off each side until I got it close enough to the lowered part in the seat back that I could then trim short sections off where my cuts were rougher. The corners especially look worse in person up close since I basically just guessed the curve on the corners and kept trimming until each corner fit too but in practice they're easily not noticed.
    I found the double-sided tape was nearly the same depth as the rides in the cutout, so I laid my tape strips between the ridges and then just stuck each rubber part down. If you see the lighting in the pictures, you can tell the rubber is not perfectly flat though and has some minor ridges running along it, but in person it's hard to see most of the time fortunately.
  14. Aug 6, 2023 at 1:00 PM
    SnuggleTruck
    Alex
    Fort Myers
    2020 DCLB TRD OR
    Finished my project after having the matting sitting in my closet for a few months. Wish I would have done this sooner as nothing slides around back there anymore!
    Thank you for the ideas everyone!
