Double Cab rear seat rattle
Discussion in '1st Gen. Tacomas (1995-2004)' started by mjhenks, Feb 19, 2010.
  1. Feb 19, 2010 at 10:24 AM
    mjhenks
    mjhenks [OP] Well-Known Member
    So.Cal
    04 Jade Green TRD V6 DC
    Is it common for the rear seat on double cabs to rattle? My 04 drivers side seat back rattles alot when someone is sitting in it. Pulled the hinge cover and the bushing seams really loose. The noise is coming from the latch up top but the movement seams to be because the pivot bushings are really loose. (At least the bushing on the outside)
    Thanks for the help.
  2. Feb 19, 2010 at 10:29 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    first i ever heard of that issue...
  3. Feb 19, 2010 at 3:58 PM
    scriber007
    scriber007 Well-Known Member
    Just put duct tape or electrical tape on the metal latch, that comes in contact with the rubber part. I was complaining of the same thing before. The rattle noise went away. But first tighten the loose part first.
  4. Feb 19, 2010 at 5:22 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    i had a rattle noise once upon a time.. there is a box behind the seat (on mine anyway) that sometimes becomes loose...take it off and put it back on and it goes away
  5. Feb 19, 2010 at 5:27 PM
    mjhenks
    So.Cal
    Thank you for the input. For sure this is not something behind the seat hitting the seat. Only thing back there is the jack and it is on the passenger side. It is the actual seat. I was shocked at how loose the bushings were. Not what i expected.
    Sounds like this may not be normal? Will do some more investigation this weekend.
  6. Feb 27, 2010 at 7:31 PM
    trevthefatty
    trevthefatty Wheelin' the Great White North
    Consecon, Ontario Canada
    04 V6 TRD
    Toytec Coilovers, URD MAF calibrator, remote start, deck plate & grey wire etc.......lots of little mods....
    i had this problem with my rear bench seat in my double cab....when I first got the truck I was living in St. John N.B. Canada and the roads are ridiculously awful and it would rattle over every bump....
    the white/clear plastic bushing on the pin where the seat actually folds was all worn out so I just wrapped it with tape like above...perfect fix! Just watch if you're constantly jamming something like winter coats behind the seat or hard on the seat when you're folding it....or else you're cut through the tape pretty quick..
