Double Cab Roof Rack for an Access Cab?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gavonder, Jan 15, 2008.
  1. Mar 23, 2009 at 1:27 PM
    gavonder
    gavonder [OP] She's Kickass!
    Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    Since I probably will end up cutting the rack, I've been searching for a used rack, or one for a good price.
    I have not found one yet, but I'm still searching, and do want to try this.
    I still do not know if the access cab has the mounts under the rubber strips.
    GA
  2. Mar 23, 2009 at 1:33 PM
    adkevos
    adkevos Active Member
    NY
    07 4x4
  3. Mar 23, 2009 at 1:47 PM
    gavonder
    Ct
    We know it will not fit as is, but we are interested in cutting or modifying it to fit.
    Thanks
    GA
  4. Mar 23, 2009 at 1:51 PM
    adkevos
    NY
    07 4x4
    I agree as is won't work, but I think they can be modified. I'm ordering a set and will let you know the results.
  5. Mar 23, 2009 at 1:54 PM
    sbeau1960
    sbeau1960 Well-Known Member
    Scott
    Indianapolis
    09 Tacoma Double Cab TRD Sport Pyrite Mica
    In the market for a Thule rack, had just been researching them this afternoon when I ran across this post. PM sent.
  6. Mar 23, 2009 at 4:02 PM
    wildtsail
    wildtsail Member
    Newport, RI
    Silver TRD Off Road
    I have a Thule roofrack system I took off my Nissan Maxima after using for a couple months.
    It's the same footpack, the 400XT as the tacoma.
    I'll sell them to you at 50% off the new price.
    I can get you a fit kit for the tacoma at dealer cost i'm guessing $40ish.
    I can also get you the load bars at dealer cost, I have 78"s on there now and can get you shorter ones.
    Email me if interested Todd Dot Riccardi at gmail dot com
  7. Apr 1, 2009 at 6:01 AM
    adkevos
    NY
    07 4x4
    I got the factory rack today. It looks like I'll have to cut 12" out of the center. The rack is completely flat in the center so it shouldn't be a problem. Also it will require drilling holes in the roof. The DC has weldnuts buried under the ditch molding. I"ll just install my own and seal them up good. I probably won't get to this until next week, I'll post up with pictures when I get under way.
  8. Apr 1, 2009 at 6:05 AM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    awesome cant wait to see how it turns out!
  9. Apr 1, 2009 at 11:58 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    How do you plan to reconnect the rack sections after you cut out the ~12"? Also like to see detailed pics how you drill and seal the holes. Good luck!
  10. Apr 1, 2009 at 12:04 PM
    adkevos
    NY
    07 4x4
    Since the housing is an ABS of some sort, I'll probably epoxy some sort of patch from the inside. I'll let you know what I come up with. If it comes out real nice I'll take orders.
  11. Apr 1, 2009 at 3:31 PM
    gavonder
    Ct
    Great! Looking forward to the finished product. Good luck!
    GA
  12. Apr 1, 2009 at 5:23 PM
    Raylo
    MD, USA
    Something like a piece of hardwood (maybe a dowel?) whittled down to a shape that approximates a press fit with a few inch ovelap on both sides of the cut and slathered with epoxy should do the trick nicely. Anxious to see the roof drilling.
  13. Apr 24, 2009 at 12:36 PM
    adkevos
    NY
    07 4x4
    Ok here is the finished product.
    First I'll explain it:
    I removed 12.75 inches from the center of the rack. You will see how I rejoined it right on one of the recesses.
    I then cut 4 patches out of the remaining pieces to use on the inside. I glued the sections together as well as embedded galvanized wire from some fence to add some strength. I used the two part epoxy you'll see in the pictures I got from my local autobody supply house.
    While the glue was a bit flexible I set it back down on the roof to make sure it formed well. I left it there overnight to dry.
    I then sanded it down with 800 grit and applied a black bumper and trim polish (not pictured) in a shoe polish type applicator to bring the shine back.
    To install I removed the headliner and drilled through the roof as the access cab does not have the factory installed weldbolts. The roof rack came with some caulking type washers that do a nice job of sealing it up but to be sure I siliconed all bolts again. I just came back from the car wash and no leaks.
    Hopefully the pictures will answer any questions.
    http://picasaweb.google.com/Court11...?authkey=Gv1sRgCLyN8bSB4o3Fdw&feat=directlink
    TurboGT likes this.
  14. Apr 24, 2009 at 2:28 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    VERY nice job! :thumbsup:
  15. Apr 24, 2009 at 2:38 PM
    #35
    mainland_newfie
    mainland_newfie Mainland Newfie
    ontario, canada
    TRD Tacoma
    skid plate, side step rails, new rims, hose clamp, 20% tint, G4 Tonneau cover, JVC 7 in double din stereo/dvd
    the last guy to respond to whose got an indigo ink truck has the roof rack on his access cab
  16. Apr 24, 2009 at 3:04 PM
    #36
    adkevos
    NY
    07 4x4
    That was me.
  17. Apr 24, 2009 at 3:16 PM
    #37
    gavonder
    Ct
    WOW!! That looks great!! I think it looks better than on the DC.
    I knew it could be done, but I still don't think I have the guts to drill through the roof. The main thing I'm afraid of is it possibly not fitting due to my sunroof, and then wind noise with the sunroof.
    Great job, though.
    GA
  18. Apr 24, 2009 at 3:28 PM
    #38
    rmb_crew
    That looks awesome dude. I really want to do this now!!!
  19. Apr 24, 2009 at 4:11 PM
    #39
    adkevos
    NY
    07 4x4
    There is some noise but not bad, although I don't have a sunroof. Drilling the roof really is no big deal, just need to thorough on sealing the holes. I want to add the sunroof, so I can let you know on the noise. Speaking of holes in the roof the sunroof is much bigger.:D
  20. Apr 24, 2009 at 4:16 PM
    #40
    Southernsurfer
    Southernsurfer Well-Known Member
    FL
    2007 DC LB 4X4 TRD Sport
    Bilstein 5100 Rears & Fronts @ 1.75 / TSB 4 Leaf Pak / TRD FJ SE Anthracite wheels w/ BFG AT KO's 265/75/16 / Satoshi Grille w/Hella 500's / Blacked Out headlights / OEM LED Tail lights / 15% Llumar Tint De-Badged / OEM Front Skid Plate / Vinyl/Leather arm-rest mod / Weather Tech mats / TRD seat covers / Tacoma LB Bed mat / Door sill protectors / OEM Class IV Hitch / JL 500/1 w/2 JL 10" Subs / JL Audio Frnt & Rear speakers / Alpine IVA-W505 w/Bypass
    Excellent Job!
