Double cab v6 "bumps" at traffic lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HHG, Nov 7, 2012.
  1. Nov 7, 2012 at 3:17 PM
    Nixinus
    Nixinus Well-Known Member
    I believe there is a TSB for this.
  2. Nov 7, 2012 at 3:18 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    it's not the transmission
  3. Nov 7, 2012 at 3:21 PM
    Bfry86
    Bfry86 Well-Known Member
    Brandon
    Floyds Knobs, Indiana
    2010 SR5 DCLB TRD Sport 4X4
    10 gauge steel Skid Plate PC'd "Raptor" Satoshi grill
    Mine deoes the same from time to time. I seriously thought I got rear ended the first time. Strange...
  4. Nov 7, 2012 at 3:25 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Axle wrap. Next time you drive try this, come to a very abrupt stop pushing the brake pedal hard and once you stop push on the brakes as hard as you can. You will feel the "thump" as soon as you let off the brakes slightly. It because when you stop fast your front end dives and the rear end raises, when you come to a complete stop the truck settles but your holding your foot on the brake which causes the rear leafs to load up, as soon as you relieve enough brake pressure to allow the rear drums to slip the rear springs unload and you feel a thump. Do it a few times and hold the brakes for a different amount of time to test, it wont thump until you release the brakes slightly
  5. Nov 7, 2012 at 3:34 PM
    fletch97
    fletch97 Professional Window Licker
    NJ
    2013 Tacoma SR5
    Mine does the same thing but it only seems to happen I have the fan on, whether heat or AC. It doesn't do it when the fan is off.....that's the only pattern I have found.
    BTW.....I have a 2013 Tacoma SR5 with a little over a 1000 miles.
  6. Nov 7, 2012 at 3:41 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    I've had my truck for 14 months and this has been doing it since the 2nd day I got it. The first time it happened I pulled over because I thought that the truck behind me had hit me. Turns out it has to do with the truck shifting into first gear(I have an auto). I was told that it was normal.
  7. Nov 7, 2012 at 3:43 PM
    GhostDog86
    GhostDog86 Well-Known Member
    Max
    Chimayo/Santa Fe
    DCSB TRD OR
    Remove mudflaps, Plasti dip badges/ lower val/ and grill, Plasti dip wheels, 5% tint all around, Tinted tails and 3rd, 55w driving lights in rear, Blue LED light strip in bed, Blue LEDs in cab/ cup holders...
    Mine does the same thing. Iv seen it happen on other makes and what I noticed is there would be a slight increase in RPM right when I would feel the "bump". I always let it fly thinking it was the tranny shifting down.
  8. Nov 7, 2012 at 4:20 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    You have 10 ppl telling you it's not the trans. Don't waste your money going to a shop. Leave your ac off and see if it still does it. If it does, it's a axle wrap. If it doesn't do it, it's the compressor kicking on momentarily. Both of my tacomas have done this and my xrunner had axle wrap before I put I the urd torque arm
  9. Nov 7, 2012 at 4:47 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Did you recently start using defrost ?
  10. Nov 7, 2012 at 5:19 PM
    HHG
    HHG [OP] Member
    Nope, been using the ac on defrost and all other settings for a long time. Sounds like I need to check for axel wrap. Thanks for the advice everyone! I love the truck. Any recommendations on stereo head?
  11. Nov 7, 2012 at 5:21 PM
    Nixinus
    Check the torque on the u-bolts. Apparently many members have been saying they were 'hand tight' when they should be 73 ft/lbs.
  12. Nov 7, 2012 at 5:51 PM
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    My 2008 4runner did it when letting foot off brake pedal after a complete stop or when stopped and slowly moving suv forward.
  13. Nov 7, 2012 at 6:12 PM
    Drinknmolson
    Drinknmolson Well-Known Member
    Wheat Ridge, CO
    10 DCSB sport
    I have the same problem, went to the stealership for the Tranny TSB and the guy asked me if I had the feeling of being rearended after I have some to or been at a stop, I said yah that's why I am here, he said they all do that. then after having my truck all day for the TSB (which they were pissed that I had a pdf printed out for it) they had me come get the truck and told me the CPU was locked and wouldn't accept programming.
    good luck, I wonder if I get a little whiplash if they will fix it?!
    love my truck, tryn to get used to the quirks.
  14. Nov 7, 2012 at 6:14 PM
    OZ-T
    Peter North
    British Columbia
    wut
  15. Nov 7, 2012 at 6:27 PM
    #35
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    02 PreRunner DoubleCab TRD
    Bull bar, nerf bars, bed extender, tonneu cover, bug deflector, wish list,....
    It IS the transmission. I am not saying that it can't happen with AC and axle wrap also, but I know that the transmission will do it, i.e. I am not just guessing, it's a fact.
  16. Nov 7, 2012 at 6:30 PM
    #36
    HHG
    HHG [OP] Member
    Great ideas! Thanks!
  17. Nov 7, 2012 at 6:57 PM
    #37
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    And what would be your proof? Because it definitely is not the transmission. If it were, my truck would be doing it for the last 5+ years when my A/C is completely off.
    Man we've beaten this horse so many times over the years lol
  18. Nov 7, 2012 at 7:29 PM
    #38
    gasgasman
    gasgasman ASE Master Tech.
    Pearland Texas
    2013 Tacoma, double cab, pre-runner
    Mine does it. Not the A/C, it does it with the A/C off.
    I always catch myself looking in the mirror to see who hit me.:(
  19. Nov 7, 2012 at 7:30 PM
    #39
    OZ-T
    Peter North
    British Columbia
    Do you use defrost ?
  20. Nov 7, 2012 at 8:12 PM
    #40
    tacoroad
    tacoroad Member
    Texas
    4x4 TRD Off Road
    I think it has something to do with the torque converter solenoid resetting. My 2013 tacoma is the first automatic in 20+ years. I usually feel it when I have been driving fast and come to an abrupt stop, about 2-4 seconds later. I looked up other truck and car forums with the same type of system, and they are asking the same question.
