Double Cardan Driveshaft: V6-4WD-DCSB
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 1MK, Mar 28, 2017.
  1. Mar 28, 2017 at 8:05 PM
    1MK
    1MK [OP] Desert Explorer
    Southern California
    Has about 10,000 miles on it. Rebuilt about 1,500 miles ago. Story is my truck is a heavy pig and probably well outside intended operating limits and this driveshaft setup doesn't like it. As a result the first version ended up sheering the midship stub. It has since been replaced and works great, but I ended up going to a different setup that's more capable of handling the weight and stresses that the truck gets put through.
    Located in Murrieta, CA.
    $440.00
  2. Mar 30, 2017 at 6:14 PM
    1MK
    Southern California
    $495.00
  3. Mar 30, 2017 at 6:17 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
  4. Apr 4, 2017 at 12:45 PM
    1MK
    Southern California
    $450.00
  5. Apr 4, 2017 at 3:01 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  6. Apr 4, 2017 at 3:13 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    What kind of truck Reg cab, DCSB, ACLB, DCLB?
  7. Apr 4, 2017 at 3:16 PM
    fatfurious2
    David
    Ashburn, VA
    Tatts521 and 1MK[OP] like this.
  8. Apr 4, 2017 at 3:17 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    LOL who reads titles.
    1MK[OP] and fatfurious2[QUOTED] like this.
  9. Apr 4, 2017 at 3:18 PM
    fatfurious2
    David
    Ashburn, VA
    Blkvoodoo and 1MK[OP] like this.
  10. Apr 5, 2017 at 4:40 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Good price fellas! I have a similar drive shaft(worked excellent to eliminate my vibration issues) and was more expensive then this...
    1MK[OP] likes this.
  11. Apr 12, 2017 at 3:02 PM
    1MK
    Southern California
    $440.00
  12. Apr 12, 2017 at 10:56 PM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    That price makes me want to buy a trail spare...
  13. Apr 13, 2017 at 11:36 AM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    @1MK Just so I understand this is an OEM driveshaft with a DC joint added, correct?
    Can you measure the flange? I think there may be variations even within Gen2 trucks but not 100% sure. I know Tom Woods insists to get these right.
  14. Apr 13, 2017 at 11:58 AM
    1MK
    Southern California
    The front portion is a stock Toyota shaft, with a custom rear section.
    All 2nd Gen flanges are the same diameter.
    A - 1.812"
    B - 3.675"
    C - 2.6"
  15. Apr 13, 2017 at 12:10 PM
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    Thanks, I keep going back and forth on something like this or a 1 piece. I get slight vibrations around 65-70 mph. Was worse before I balanced the tires but its still there. Already put in solid motor mounts so it's either CBearing or driveshaft out of balance. Need to check the driveline angles but my truck is only slightly lifted so I don't think that's the issue. Been reading your other thread too.
    This setup would be better for ground clearance but since I rarely get off road I may be better off just going 1 piece... 1rst S/C'd world truck problems :burnrubber:
