double cardan joint replacement help
Discussion in '1st Gen. Tacomas (1995-2004)' started by mixaro, Aug 22, 2011.
  1. Aug 22, 2011 at 6:17 AM
    mixaro
    mixaro [OP] Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    ok i have a 02 extended cab and i'm getting the u joint squeak. So i just went to town and replaced all the u joint (it had been a while and i figured i might as well do them all). so i did the 2 on the rear drive shaft and the 2 on the front drive shaft. Well that didn't fix the squeak. So i dug further and i checked the center support bearing and that fine, then come to find out it's the double cardan joint. I called toyota about it and they say it's a none replacable part, and that i had to buy an entire drive shaft. Now i'm just wondering if i can replace the u joints in it and the little bearing also, and how much of a pain in the a$$ it is, and what the part numbers may be.
  2. Aug 22, 2011 at 6:36 AM
    98tacoma27
    Ben
    Not Beech Creek
    I'm not 100% sure but aren't they just u-joints?
  3. Aug 22, 2011 at 6:53 AM
    mixaro
    maine
    yeah thats what they look like but from what i've found out is that they are a difference size then the ones on the rest of the drive shaft
  4. Aug 22, 2011 at 10:50 AM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    I just had the U-joints in my rear drive shaft replaced. I took it to Inland Truck Parts. They can get after market replacement u-joints for the whole shaft and have the center ball kit. Lucky for me the double cardan joint was okay and didn't need any work.
    If you do it yourself, it is a pain. I did the one on my old 94 Toyota, not realizing what I tore into when I started. It took several hours and lots of cussing to get it back together. I swore I would never do another one.
  5. Aug 22, 2011 at 5:07 PM
    mixaro
    maine
    ha ha that seems to pretty much be the census with them. I'm thinking i might just try to find one at a salvage yard that is still good.
  6. Aug 22, 2011 at 6:16 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    i had the same problem i was unsuccessful at finding a u-joint that was the same to fit the cardaqn joint i ended up getting a driveshaft for 135 bucks with 70k on it from a junkyard a few hours out of town check out car-part.com for junkyards in your area thats how i found mine you might find one for cheap.
