Double check my hypothetical setup.
Discussion in 'New Members' started by DarthTarmac, Sep 1, 2014.
  1. Sep 1, 2014 at 12:13 PM
    DarthTarmac
    DarthTarmac [OP] Well-Known Member
    Craig
    Paducah KY
    Lifted, 33'd, and Murdered
    TRD Off-Road Package, Method Mesh 17x8.5 0 offset, Toyo Open Country AT2 285/70/17, Bilstein 5100 front and rear, OME 885, Wheeler's Progressive 3 leaf, OME Driveline Carrier Bearing Drop Kit, Depo black housed head lights, OEM 2011 TRD Sport grill color matched, Toyota accessory skid plate, bed linered rear bumper, black Kuat NV, Tepui Kukenam Sky RTT
    First post. So I might get a 2008 double cab 4x4 with the off road package in a couple of days. I've been trying to research lifts and tires sizes, like everyone else does. As of now I'm thinking I want the OME full lift from wheelers. It's the 885s in the front, dakars in the rear with their shocks and struts. I do not plan on adding spacers to make it the full 3 inch lift, it should be about 2 in the rear and 2 1/4 up front. If I run some 17x8.5 +0 wheels, will I be able to run 285-70-17 tires? From what I've see, I think I can but I want to double check before I order all of this stuff.
  2. Sep 1, 2014 at 9:14 PM
    PackMatt
    PackMatt PackMule
    James
    Norco,CA
    4x4 reg cab taco
    ARB OME 3in lift, 33's on FJ rims, ARB air lockers, 4.88 gears, snugtop shell.
    I put the Old Man Emu on my 2014 reg cab with a 4 cylinder, I absolutely love it. My truck is a lot lighter so I got 3 inches or more lift. I put 285/70r17 on FJ rims. My 4 cylinder didn't want to turn those big tires so I swapped my 4.10s with 4.88s. Runs perfect now.
