Double Checking/ Rear Shock Question
Discussion in 'Suspension' started by Uncharted, Aug 3, 2009.
  1. Aug 3, 2009 at 1:25 PM
    Uncharted
    Uncharted [OP] Well-Known Member
    Phoenix, AZ
    08 Taco
    Icon Extended Travel C/O's, TC UCA's, 285/70/17 Hankook Dynapro MT's, 17" XD Revolvers, Avid Off Road Sliders, Toytec TSB AAL, Rear 5100's, All Pro Front Bumper & Skids, Color Matched Grill, Grillcraft Upper, BHLM, Tinted Taillights, Lightforce 240's.
    So I decided to take the plunge and lift my Taco! I just wanted to double check I got everything coming that I need.
    Icon Extended Travel CO's...ordered
    Icon CO Spanner Wrench...ordered
    Toytec AAL for TSB...ordered
    Toytec Diff Drop kit...ordered
    XD revolvers....ordered
    285/70/17 Hankook Dynapro MT...ordered
    Total Chaos UCA's...sitting in my living room
    I know I need some rear shocks but was uncertain which would be the best for my setup. Any Suggestions are greatly appreciated! Also if I'm missing anything let me know!:)
  2. Aug 3, 2009 at 1:37 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    5125's with a universal pin to eyelet would work.
    You may not need the diff drop, install everything else and then see how the truck feels. If you have vibrations, try the drop. If you don't, sell it.
  3. Aug 3, 2009 at 3:28 PM
    bjamison01
    bjamison01 Member
    Brent
    Sacramento, CA
    09 Taco DC 4x4 Sport
    Icon C/Os, TC UCAs, Rear Billie 5100's, Toytec AAL, Shim, Moto Metal 955's (machined), Nitto TGs 285/70/17.
    I'm in the process of installing an almost identical setup. I went with 5100 rear billies for the shocks and am also adding a toytec 3 degree axle shim.
    None of this has been installed yet though, so take my advice with a grain of salt.
  4. Aug 3, 2009 at 3:59 PM
    Uncharted
    Phoenix, AZ
    08 Taco
    Sounds good. I was leaning towards the 5100s or some OME shocks for the rear but couldn't decide. I'm going to keep my fingers crossed and hope for no vibrations.
  5. Aug 3, 2009 at 6:08 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    you can get some nice fox reservoir's from all pro for the rear, looks like you have everything else covered.
  6. Aug 4, 2009 at 12:17 AM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    Icon up front and Fox in the rear, I wouldn't do that. I am sure it would function fine, but mixing brands like that is kinda ghetto fab. Then again I do have Icons with 5100s in the rear, but that is different.
  7. Aug 4, 2009 at 6:10 AM
    bajamoon
    STEVE
    Whittier
    double standard he, do you still have your truck.
  8. Aug 4, 2009 at 6:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Your gonna have to install some limit straps to the front, otherwise, the coils are gonna hit the UCA when your shocks extend.
  9. Aug 4, 2009 at 9:29 AM
    DylanICON
    DylanICON Suspension Guy
    Dylan
    Corona, CA
    07 Tundra, 02 Tacoma
    Long travel, coilover, 2.5" ICON piggy backs, SC, Glass, 35", 4.88, HID's, ect.
    The shocks have an internal limiter that stops it before the arm hits the coils. You should be fine without a limit strap.
  10. Aug 4, 2009 at 1:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to know! Is this a new feature?
  11. Aug 4, 2009 at 2:34 PM
    DylanICON
    Dylan
    Corona, CA
    No. The internal extension damper has always been a feature of all our shocks. It cushions the residual energy left in the suspension when it gets to the end off the travel so it doesn’t bang. It’s like a limit strap but it uses springs and hydraulics inside the shock. It is also much more precise than a strap that needs to be adjusted periodically as it stretches.
    The difference between the standard and extended is the standard stops the suspension just before the stock upper arm hits the coil and the ball joint binds. The extended will droop a little farther because the aftermarket arm has better clearance and more angularity in the uniball.
    On a race car I would use a strap as well and use the shock extension damper as a redundancy.
  12. Aug 4, 2009 at 4:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Interesting.....I read on TTORA alot of folks that use the extended ones were running limit straps, but I may have misunderstood. Thanks for clearing that up for me. :)
  13. Aug 4, 2009 at 10:45 PM
    Uncharted
    Phoenix, AZ
    08 Taco
    Thanks for all the input so far. Good to know I pretty much have everything I need except the rear shocks.
    I was tempted to order them but figured I already dropped enough cash. Is there a noticeable difference with having remote res in the rear?
  14. Aug 4, 2009 at 10:48 PM
    bajamoon
    STEVE
    Whittier
    no noticeable diff, save yourself some money and get the 5100's, you will not notice anything.
  15. Aug 4, 2009 at 11:00 PM
    Kenny650
    Kenny650 Well-Known Member
    Good to know. Thanks! :D
  16. Aug 7, 2009 at 6:08 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
  17. Aug 7, 2009 at 7:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The shims should fix it.
  18. Aug 7, 2009 at 8:49 PM
    HBMurphy
    Paul
    So California Coast
    None
  19. Aug 7, 2009 at 11:08 PM
    bajamoon
    STEVE
    Whittier
    you can also try the cb drop, i had the shims and made it worse, now i have a very very small vib under 5 mph.
  20. Aug 8, 2009 at 8:30 PM
    HBMurphy
    Paul
    So California Coast
    None
