Double checking with TW members
Discussion in 'Suspension' started by 06sr5prerunner, Aug 19, 2012.
  1. Aug 19, 2012 at 2:14 PM
    06sr5prerunner
    06sr5prerunner [OP] DILIGAF
    luis
    midland tx
    2006 sr5 prerunner
    bhlm paint wheels duplicolor plasti dip white grill. billies 5100. bf goodrich at 285's 75 16 black valence led corner lights expedition bed rack by anb fabrication spidertrax wheel spacers rotopax fuel tanks 4gal mounted on bed rack quickfist mounts for shovel. ddm hid kit 35watt 6000k hi/low beam
    hey guys just had billies installed in the front of my truck. Set @1.75. I was gonna ride like this for a while since i was going to purchase maxtrac spindles and all pro leaf pack will be holding back on that for a while. So thinking of purchasing eibach coils from toytec to add to my billies to get 3" lift in the front. and 2" AAL.
    just to make sure this is what i have planned to buy for my pre runner:
    - Eibach coils to install in billies @ 1.75 for front 3" lift (lR uca's later down the road.
    -Extended brake lines for the front
    Rear AAL and with u bolts included. w rear billies 5125 shocks
    - would i need extended brake lines for the rear too?
    soooo am I missing something. for a temporary lift till my truck is ready for spindles. :D
  2. Aug 19, 2012 at 4:22 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Don't take me as right, but I don't think you need brake lines in both front or rear, the 5100's in the rear are fine, and you can't go past .85 with the Eibachs, so you should probably get a spacer lift to finish the 3". But then again I'm pretty wrote off when in comes to suspension, so wait for normal people to respond
  3. Aug 19, 2012 at 6:11 PM
    06sr5prerunner
    luis
    midland tx
    2006 sr5 prerunner
    i seen that too i think its like a 1/4 inch spacer but im not sure. yea hopefully somebody who has or done this set up can pitch in.
  4. Aug 19, 2012 at 7:24 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Well I just bought the Eibachs and the 1.5" 5th leafs myself to go with my 4 5100s so I would be pretty pissed if it doesn't work out for me lol
  5. Aug 19, 2012 at 8:20 PM
    06sr5prerunner
    luis
    midland tx
    2006 sr5 prerunner
    1.5 aal is tsb right? did you get extended brake lines?
  6. Aug 20, 2012 at 2:59 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    No its not. Its the same as the 2" aal but for trucks WITH the TSB. I didn't order or ever hear of extended brake lines
  7. Aug 20, 2012 at 7:14 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    You only need extended brake lines if you are lifting the rear 3" or more
  8. Aug 20, 2012 at 7:43 AM
    Large
    Large Red
    Using full OME setup & dakars, fully flexed with stock brake lines & no issues.
  9. Aug 20, 2012 at 7:30 PM
    06sr5prerunner
    luis
    midland tx
    2006 sr5 prerunner
    sounds good. thanks for helping me save some money. so the highest you can billies with the eibach springs is @ .85?
  10. Aug 20, 2012 at 8:31 PM
    OZ-T
    Peter North
    British Columbia
    Yes
  11. Aug 21, 2012 at 3:38 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Ya then 1/4" spacers give you another 1/2", or 1/2" spacers give you about 3/4". I'm probably just sticking with .85 and Eibachs though.
