Double prong spark plugs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by crakumskull, Feb 7, 2021.
  1. Feb 7, 2021 at 9:50 AM
    crakumskull
    crakumskull [OP] Well-Known Member
    tony
    Oregon
    2000 tacoma stock as $#!+
    Modified my clutch spring if that counts
    I am wondering about the double electrode plugs vs the other style on my truck. I bought NGK ruthenium and the parts site said they will fit. And then i notice a sticker that says its imperative to use the double prong type
  2. Feb 7, 2021 at 9:52 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Use what the owners manual lists in the back.
    jbrandt and Hobbs like this.
  3. Feb 7, 2021 at 9:52 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Check your Owner's Manual for the recommended spark plugs.
    I know my '06 doesn't require plugs of that nature.
  4. Feb 7, 2021 at 9:55 AM
    crakumskull
    tony
    Oregon
    I don't have one but theres a sticker right there in my face so im gonna hafta go with those im assuming
    Tacoma Mike likes this.
  5. Feb 7, 2021 at 9:59 AM
    Knute
    Interesting.....
    Ask, then ignore based on a sticker.
    Your truck, your cash, your choice.
    whatstcp likes this.
  6. Feb 7, 2021 at 10:36 AM
    crakumskull
    tony
    Oregon
    I dont have an owners manual
  7. Feb 7, 2021 at 11:01 AM
    Knute
    Ok.....I just dug around on RockAuto for you.
    The 3.4 L uses a double electrode plug.
    I suggest you find an Owner's Manual. It will have much information about fluids, spark plugs, towing, operation of the truck.........
    I'll wager the local Toyota dealer could supply a manual or dig around on the internet for a downloadable PDF version.
  8. Feb 7, 2021 at 11:25 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    a400ryan, jbrandt and JudoJohn like this.
  9. Feb 7, 2021 at 11:29 AM
    Knute
    Sometimes its simpler to give them a fish instead of teaching them how to fish.
  10. Feb 7, 2021 at 11:34 AM
    crakumskull
    tony
    Oregon
    Thanks for the help
    Black DOG Lila likes this.
  11. Feb 7, 2021 at 11:43 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    You don't need to use double prong with platinum and above. Double electrode is to extend the service life of traditional spark plugs due to the high intensity coil packs Toyota put on these trucks from the factory.
    Just ensure spark gap is correct, and check life every 20k miles or so.
    That said, if they somehow offer the upgraded plugs in double electrode, go for it.
    Bigal90 likes this.
  12. Feb 7, 2021 at 11:54 AM
    Woodcutter
    Woodcutter Well-Known Member
    St. Petersburg Florida
    96 Taco 4 x 4 SR5
    Extremely important that the right spark plug be used. If your truck has been running fine and this is just preventative pull one plug and use the same as installed. Also you could post information on your truck, including model, transmission, engine, etc, and perhaps someone with the same can be of help. Good luck! Woodcutter
    JJ04TACO likes this.
  13. Feb 7, 2021 at 12:01 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    But you have google.
    Wyoming09 and whatstcp like this.
  14. Feb 7, 2021 at 12:02 PM
    crakumskull
    tony
    Oregon
    2000 taco. 3.4l 5fvze. 5 speed manual trans. 4 wheel drive.
    Every site i look at, including rock auto, has both types of plug at a .044 gap.
    I was hoping it was a performance thing with the double electrode so i went with the ruthenium ultra premium plugs, from rock auto.
    I looked up those part numbers and both style show up.
  15. Feb 7, 2021 at 12:02 PM
    blind cowboy
    blind cowboy Well-Known Member
    Don
    Auburn CA
    2002 TRD XC 5sp
    There's a reason Toyota put that sticker there.
    crakumskull[OP] likes this.
  16. Feb 7, 2021 at 12:04 PM
    crakumskull
    tony
    Oregon
    Maybe I will get 3 of each hahaha
    beignet and Black DOG Lila like this.
  17. Feb 7, 2021 at 12:06 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Plug gap on the v6 is 0.043"
    The reason for double is that the spark will alternate between the two electrodes and wear them evenly, given what I previously said. It has nothing to do with performance. Most people here are OEM purists; if pappy says it, don't question it.
  18. Feb 7, 2021 at 12:49 PM
    crakumskull
    tony
    Oregon
    Well thanks for the help. I appreciate it im half done now. No turnin back
  19. Feb 7, 2021 at 12:58 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    If you look the 3.4 has only 3 coils on one side with wires going over the the other side. That engine fires a spark on the compression stroke and also to the corresponding cylinder at the exhaust stroke. It’s considered a wasted spark engine. Because it fires twice as often it uses a double electrode plug. The spark will fire on the closest electrode then switch to the other one when it wears. Technically you could use single electrode plugs but you’d have to change then twice as often.
  20. Feb 7, 2021 at 2:36 PM
    crakumskull
    tony
    Oregon
    Ah i see. That makes sense. I bought the "ultra premium" version that are supposed to last 100,000 miles so time will tell.
    Thanks again y'all
    Starts up alot quicker now
