Double prong spark plugs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by crakumskull, Feb 7, 2021.
  1. May 27, 2021 at 3:50 PM
    Milor
    Milor Well-Known Member
    shaun
    03 Tacoma sr5 .TrD offroad 5spd..
    supercharged 2" pulley 6 puck clutch
    did you gap them to the .043? out of the box they were .030 I'm putting them in today for my supercharged truck
  2. May 27, 2021 at 3:58 PM
    crakumskull
    crakumskull [OP] Well-Known Member
    tony
    Oregon
    2000 tacoma stock as $#!+
    Modified my clutch spring if that counts
    I used a ruthenium plug pre gapped out of the box and havent had issues yet. They were not double pronged. If you are going OEM i would assume you will be fine
  3. May 27, 2021 at 5:47 PM
    Milor
    shaun
    I went with the NGK RUTHENIUM PART# FR7BHX-S which are 2 step colder plugs than stock. Before That I ran Denso Iridium IK-22 I havn't ran "OEM" in years
  4. May 27, 2021 at 6:11 PM
    crakumskull
    tony
    Oregon
    I reckon you should be good to go then yeah? Same ones i used
    Milor likes this.
  5. May 28, 2021 at 3:10 AM
    Igpoe
    Igpoe Member
    1995 base,manual
    None
    What is " Ruthenium" anyway?
  6. May 28, 2021 at 3:19 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Ruthenium is a rare element related to Platinum. It is a Nobel metal far superior to steel in extreme invironments. Like inside the combustion chamber of a high compression engine at 4,000 RPM.
    Milor likes this.
  7. May 28, 2021 at 6:05 AM
    crakumskull
    tony
    Oregon
    They say it far outlasts the iridium version. Ive had zero issues so far. Ive put around 2k on em
    Milor likes this.
  8. May 28, 2021 at 6:10 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Or maybe just pull one out and see what you have in there now? And buy the same thing?
