DOUBLLD Master cylinder UPGRADE feeler
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by DOUBLLD, Jan 24, 2017.
  1. Jan 25, 2017 at 8:36 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Let me refine what lackadaisical pre coffee comment that I had earlier.
    The fluid level sensor on the OEM reservoir. If left unplugged, or the fluid is to low, the ABS light will stay on. Have you come up with an idea to remedy this?
  2. Jan 25, 2017 at 8:42 AM
    DOUBLLD
    DOUBLLD [OP] Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    i thought if unplugged nothing happened?
  3. Jan 25, 2017 at 8:46 AM
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    Interested
  4. Jan 25, 2017 at 9:11 AM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    When I was diagnosing my ABS / BRAKE lights being on the dash, I know a lot of people suggested that when that happened to them it was because of low brake fluid in the reservoir. Not sure what happens if you just unplug it, sure seems easy to find out though...
    As many of us have found out, the stock discs are prone to warping. This seems like it would be a good combo with some upgraded calipers /rotors for sure.
    I'm sure you have spent some serious time and effort in designing this, some people may be hesitant to pay 200$ for a small aluminum disc. That and if you do sell alot at 200$, What is stopping someone from re-creating your product and selling it for 100$? (unless you have patent rights) Seems to be a problem around here with newly designed products so just a thought, provisional patents allow you one year to assess the market and only cost ~60$.
    I think it is a great idea and not a crazy price especially if the initial reviews are promising.
    glorifiedwelder and DOUBLLD[OP] like this.
  5. Jan 25, 2017 at 9:17 AM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    i havent thought of a patent. this is a product to try a supply the demand for people. ill look into that thanks for the tip.
    excorcist[QUOTED] likes this.
  6. Jan 25, 2017 at 9:29 AM
    BadBrains
    AL
    Any other adapters coming down the road? BBK caliper brackets perhaps?
  7. Jan 25, 2017 at 9:32 AM
    excorcist
    Reno, NV
    I'm not well versed in braking systems, but assuming there is some real benefit to be had, and that it works well with all of the other components such as brake booster and what have you, I see some real marketability, and where there is marketability there is competition. Patent would just allow you to eliminate or mitigate the competition. It may or may not be worth it. I am working on a provisional myself and its been pretty time consuming (mainly patent drawings so you may save some serious time if you already have 3d digital renderings)
    Again it is just a thought, I guess you have to ask yourself if it is really something you would want to pursue if it did take off. If you are just making small batches and only plan on making say less than 100 or so I wouldn't think it would be worth it.
    I guess the biggest thing is going to be you testing it yourself to see if the benefits you want to see are there.
    DOUBLLD[QUOTED][OP] likes this.
  8. Jan 25, 2017 at 9:59 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Subd as my brakes suck and desperate to learn me some knowledge other than aftermarket rotors and pads are better than stock.
    DOUBLLD[OP] likes this.
  9. Jan 25, 2017 at 10:06 AM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    not from me since you can buy kits already.
  10. Jan 25, 2017 at 10:08 AM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    i believe there will be alot of benefit for this. we will see what happens on sales when i get one working.
  11. Jan 25, 2017 at 12:27 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Need that level sensor so the dash ain't lit up like a Christmas tree. Could just jumper it I suppose.
  12. Jan 25, 2017 at 12:29 PM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    yes putting the two wires should work just fine. an if its a resistance issue can always wire in a resistor.
  13. Jan 25, 2017 at 12:30 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Although it would be better just to have the sensor actually doing its job rather than bypassing it.
    excorcist likes this.
  14. Jan 25, 2017 at 1:13 PM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    you mean a low level sensor? it will have zero effect on the brakes.
  15. Jan 26, 2017 at 10:08 AM
    #35
    excorcist
    Reno, NV
    Something to look into? I have no idea if this is a direct fit for the M/C you are using but Im sure you can find something to work.
    http://www.speedwaymotors.com/Wilwo...gn=CSEGOOGLE&gclid=CI-Qscqz4NECFZS3wAodkwEExA
    jberry813 likes this.
  16. Jan 26, 2017 at 11:05 AM
    #36
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    it isnt. an i honestly dont care about a level sensor. this is purely for performance. little things like that are a none issue. once i get the adapter made and installed on a truck ill let you know about all my findings. right now it was to see who is interested in it. to make sure im not wasting my time and money.
  17. Jan 26, 2017 at 11:09 AM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just to be certain, I am interested as well. My light is always on anyway. No bother to me. A plug jumper could always be made. I just know that there will be the those whom overlooked my question, were I not to have asked it, then complained about it later.
    Now they have no reason to.
    What I would like, is for the leg work to be done to see if a quality jumper plug could go along with the kits.
    Rather than leave it solely to the buyer.
  18. Jan 26, 2017 at 11:09 AM
    #38
    excorcist
    Reno, NV
    You may not care about the level sensor but I bet most people would if you were to sell it as a kit. Again nothing more than my 2 cents.
  19. Jan 26, 2017 at 11:12 AM
    #39
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    I made one already for my truck, but your design looks like it will seal better. ( I was gunna do one like yours next)
    I'm interested in an adapter saves me from makin one
  20. Jan 26, 2017 at 11:14 AM
    #40
    excorcist
    Reno, NV
    Did you use in conjunction with upgraded brakes?
    What was your impression of the m/c upgrade?
