DOUBLLDS JUGGERNAUT LS TWIN TURBO TACO
Discussion in '2nd Gen. Builds (2005-2015)' started by DOUBLLD, Oct 24, 2016.
  1. Nov 22, 2016 at 5:06 AM
    #221
    DOUBLLD
    DOUBLLD [OP] Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    i do love me some purple.
    MarX and ChadsPride[QUOTED] like this.
  2. Nov 22, 2016 at 5:06 AM
    #222
    ChadsPride
    Sponsored by TacomaWorld.com
    So damn clean!!!!
    DOUBLLD[QUOTED][OP] likes this.
  3. Nov 22, 2016 at 5:11 AM
    #223
    ThomasMore66
    Dallas/Fort Worth & Durango
    I'm in love.
    DOUBLLD[OP] and ChadsPride like this.
  4. Nov 22, 2016 at 5:31 AM
    #224
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    i cant wait to buy the big brake kit and get the calipers powder coated to match.
    MarX and ChadsPride like this.
  5. Nov 22, 2016 at 5:33 AM
    #225
    ChadsPride
    Going to be tits broe. fucking jelly af
    Masshole_And_His_Taco likes this.
  6. Nov 22, 2016 at 5:36 AM
    #226
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    just do it lol. or send the truck with the bed full of money an ill do it for you. LOL
  7. Nov 22, 2016 at 5:38 AM
    #227
    ChadsPride
    Haha!!! Maybe one day when im old an aint got anything to do i can do a frame off job like youre doing. So freaky pretty man!
  8. Nov 22, 2016 at 5:48 AM
    #228
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    gotta do it when your young lol
    ChadsPride[QUOTED] likes this.
  9. Nov 22, 2016 at 5:53 AM
    #229
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    Going to be a tight fit for the exhaust headers...?
    ChadsPride likes this.
  10. Nov 22, 2016 at 5:54 AM
    #230
    tacot0wn
    tacot0wn Mia San Mia
    CO
    07 DCSB on 35s. Slowly becoming #EAF
  11. Nov 22, 2016 at 5:55 AM
    #231
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    negative. i already had everything in the engine bay. i took it all apart to fix the frame build engine etc. look at the first page there should be some pictures of it assembled.
    MarX, timothom[QUOTED] and ChadsPride like this.
  12. Nov 22, 2016 at 11:28 AM
    #232
    ThomasMore66
  13. Nov 22, 2016 at 11:36 AM
    #233
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Are there currently no 2nd gen turbo truck from tw on the road right now? Toon's gone, tor's i dont really even know; hes pullin the tranny right now, mine will be done in the next 1-23 months, redlanturn's running with no spring in the wastegate because reasons... Am i missing anyone? Will this become a road race as in first to the road wins?
  14. Nov 22, 2016 at 11:51 AM
    #234
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    That's a big gap of time you got there o_O
    tacot0wn, DOUBLLD[OP] and ChadsPride like this.
  15. Nov 22, 2016 at 11:53 AM
    #235
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I've got my money on DoubllD.
    timothom and ChadsPride like this.
  16. Nov 22, 2016 at 11:55 AM
    #236
    Toyko Joe
    Toyko Joe Here for the pictures
    Beautiful welding! Very skilled!
  17. Nov 22, 2016 at 11:56 AM
    #237
    yota243
    E.J.
    north Alabama
    No gap too big no crack too wide or somethin like that
    Torspd and ChadsPride like this.
  18. Nov 22, 2016 at 3:45 PM
    #238
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Who makes a big brake kit for 4x? I haven't had luck finding one and would like to get one.
  19. Nov 23, 2016 at 5:00 AM
    #239
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    lol mine i believe is a little more in depth right now. tor is def winning. my 1gr build ran for a hot second lol
    MarX, yota243[QUOTED] and ChadsPride like this.
  20. Nov 23, 2016 at 5:10 AM
    #240
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    there is a group buy now on them. http://sosperformance.com/
