DOUBLLDS JUGGERNAUT LS TWIN TURBO TACO
Discussion in '2nd Gen. Builds (2005-2015)' started by DOUBLLD, Oct 24, 2016.
  1. Nov 23, 2016 at 5:11 AM
    #241
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    DOUBLLD[OP] and ChadsPride like this.
  2. Nov 23, 2016 at 5:19 AM
    #242
    DOUBLLD
    DOUBLLD [OP] Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    is there a comparison between us? we are very different now with our builds.
    MarX and ChadsPride like this.
  3. Nov 23, 2016 at 5:27 AM
    #243
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Thanks guys, I swear I've looked for stop tech and never seen these.
  4. Nov 23, 2016 at 5:42 AM
    #244
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I just have a hunch that you'll have your truck w/turbos, running prior to mine w/turbos.
    ChadsPride likes this.
  5. Nov 23, 2016 at 6:50 AM
    #245
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    thanks im getting better
  6. Nov 23, 2016 at 6:51 AM
    #246
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    time will tell lol. still got alot of work to do
  7. Nov 23, 2016 at 8:43 AM
    #247
    ThomasMore66
    Dallas/Fort Worth & Durango
    Damn
    Damnit! I didn't know this was a "thing". I was going to stop spending on the Tacoma for a while. I want this.
  8. Nov 23, 2016 at 9:36 AM
    #248
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    me 2. send me a kit when you buy one lol
  9. Nov 23, 2016 at 10:18 AM
    #249
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Nah I'm boosting now. Finally sorted out the issues. Vband on the the exhaust was loose causing lean codes so maybe I'm the only one?
  10. Nov 23, 2016 at 10:21 AM
    #250
    RedLantern
    Honolulu, Hi
    As far as winning, I think Doublld wins on the ls platform. Torspd wins 1gr with his 15399286 motors
    Nickel, Torspd and ChadsPride like this.
  11. Nov 23, 2016 at 10:36 AM
    #251
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
  12. Nov 23, 2016 at 10:36 AM
    #252
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :laugh:
  13. Nov 23, 2016 at 10:51 AM
    #253
    RedLantern
    Honolulu, Hi
    More like wieners lol. It's Sausage party in here.
  14. Nov 23, 2016 at 10:53 AM
    #254
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    That works too...
  15. Nov 23, 2016 at 12:48 PM
    #255
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    And u got the new mcboost machina on there and no new video?
  16. Nov 23, 2016 at 1:03 PM
    #256
    RedLantern
    Honolulu, Hi
    Haha no. New one. Not on yet.
  17. Nov 23, 2016 at 1:06 PM
    #257
    yota243
    E.J.
    north Alabama
    Hurry!
  18. Nov 25, 2016 at 6:29 AM
    #258
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    i believe we all go to wienie hut juniors lol
  19. Nov 27, 2016 at 9:26 AM
    #259
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
  20. Nov 28, 2016 at 5:49 AM
    #260
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    so i got the cab back on. i got the manifolds turbos down pipes installed etc. time to finish the exhaust install everything that is gonna be in the engine bay wire the whole thing and make all the lines that are needed.
    MarX, Nickel, TacoCat and 1 other person like this.
