DOUBLLDS JUGGERNAUT LS TWIN TURBO TACO
Discussion in '2nd Gen. Builds (2005-2015)' started by DOUBLLD, Oct 24, 2016.
  1. May 22, 2017 at 5:33 AM
    #541
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
  2. May 22, 2017 at 6:31 AM
    #542
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Huh, good question. On a re-worked 6.0 on boost, it can be anything. I'd say 890-920 would be really doable with out having to squeeze your butt cheeks on every pull.
    Well there you go. It will do 1000+ because that's what he intends. Let the butt cheek squeezing commence.
    TacoCat and ChadsPride like this.
  3. May 22, 2017 at 7:23 AM
    #543
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Play by the rules mate! You have to guess at which PSI.
    ChadsPride likes this.
  4. May 22, 2017 at 7:37 AM
    #544
    Dragons Taco
    Derek
    Cary/Raleigh NC
    1000Hp@7000 with 14.5lbs total psi.
    I'd want to look at the turbo specs to see if he has the air he needs at that pressure, but it looks impressive on the truck.
    MrCrowntown, Torspd and ChadsPride like this.
  5. May 23, 2017 at 4:14 AM
    #545
    DOUBLLD
    DOUBLLD [OP] Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    only time will tell
    MarX and ChadsPride like this.
  6. Jun 8, 2017 at 9:40 PM
    #546
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I watched those episodes couple weeks ago... the gains are pretty nice but really that's to the crank. So we're only talking 4 whp. Unless I'm missing something here? :thumbsup:
  7. Jun 9, 2017 at 4:23 AM
    #547
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    no i believe you are right but still a fan to rob ponies like that why not go to a efan. colder ac quicker cool downs etc
    MarX and TacoCat like this.
  8. Jun 9, 2017 at 4:36 AM
    #548
    TacoCat
    Johnny-5
    Chantilly, VA
    I saw you posted and was hoping for more teaser pics of the truck :pout:
    Martyinco likes this.
  9. Jun 9, 2017 at 4:59 AM
    #549
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    next week been doin alot the past couple weeks
    MarX, TacoCat[QUOTED] and Nickel like this.
  10. Jun 10, 2017 at 10:11 AM
    #550
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not static. Depends on the drivetrain loss per drivetrain of whichever vehicle. The percentage loss to go from 30 hp at the crank to 4 hp at the wheels is roughly a 90% loss. That isn't happening unless your e-brake is pulled or your foot is on the brake pedal.
    Average of 15% loss, equates to roughly 25.5 whp, gain.
    So whichever fan you start with, there will be a power notice at the wheel. Having a before and after dyno always helps. :D
    DOUBLLD[OP] likes this.
  11. Jun 11, 2017 at 9:19 AM
    #551
    TRON
    You're right on the math... So this must be when the fan is fully engaged and I can see that power drop when my ac is running. But I'm having a hard time believing an efan will give 25 rwhp to our tacomas since we have a clutch fan. I wish they would have dynoed with an efan to actually see the offset.
  12. Jun 11, 2017 at 10:46 AM
    #552
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Oh no. That was just from those fans on that engine.
    We'd have to do a similar test on the 1GR, to see the principle differences.
  13. Jun 11, 2017 at 2:27 PM
    #553
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Can't wait to see this in gonna start an ls swap in my Tacoma this fall
  14. Jul 30, 2017 at 5:15 PM
    #554
    TacoCat
    Johnny-5
    Chantilly, VA
    When do we get to see some :burnrubber:
  15. Jul 30, 2017 at 5:16 PM
    #555
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Was just showing a coworker this the other day! Excited for an update.
    TacoCat likes this.
  16. Jul 30, 2017 at 5:58 PM
    #556
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Sorry fellas I need to take pictures but the exhaust is completely finished. Front core support done. About to finish the front bumper and the trim plates for the hood and exhaust exit out the side of the bed.
    MarX, timothom, BassAckwards and 6 others like this.
  17. Jul 31, 2017 at 4:36 AM
    #557
    TacoCat
    Johnny-5
    Chantilly, VA
    So it'll go thru the bedside? Or under it? No stacks on either side of the radiator? :anonymous:
  18. Jul 31, 2017 at 4:43 AM
    #558
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    it goes through the bedside behind the rear tire. same idea as a fender exit. the wastegates come out the hood.
    MarX and TacoCat[QUOTED] like this.
  19. Jul 31, 2017 at 7:40 AM
    #559
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    At least the fabrication is still moving along. Have you test fired the engine yet?
  20. Jul 31, 2017 at 8:05 AM
    #560
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Holy hell.
