DOUBLLDS JUGGERNAUT LS TWIN TURBO TACO
Discussion in '2nd Gen. Builds (2005-2015)' started by DOUBLLD, Oct 24, 2016.
  1. Mar 29, 2018 at 6:07 PM
    #881
    doorsidedown
    doorsidedown Well-Known Member
    Hell, I’m not. YOU built it!
    TacoCat and DOUBLLD[QUOTED][OP] like this.
  2. Mar 29, 2018 at 9:48 PM
    #882
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I sympathize with you.
  3. Mar 30, 2018 at 6:43 AM
    #883
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  4. Mar 30, 2018 at 7:06 AM
    #884
    DOUBLLD
    DOUBLLD [OP] Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    so much time and money finally put to the test.
    MarX, Jstand, TacoCat and 1 other person like this.
  5. Mar 30, 2018 at 9:11 AM
    #885
    largemouthdmb
    largemouthdmb Well-Known Member
    Twin Cities, MN
    2012 TRD Off-Road 4WD V6 Spruce Mica
    Wow... got here at the right time. Good luck this weekend. It's a FANTASTIC BEAST.
    (Yes, I read the whole thread...)
  6. Mar 30, 2018 at 9:16 AM
    #886
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    MarX and doorsidedown like this.
  7. Mar 31, 2018 at 12:07 PM
    #887
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
  8. Mar 31, 2018 at 12:25 PM
    #888
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    About to begin
    BYJOSHCOOK, MarX, MadTaco461 and 6 others like this.
  9. Mar 31, 2018 at 1:25 PM
    #889
    ThomasMore66
    Dallas/Fort Worth & Durango
    Pics or it didn’t happen!
  10. Mar 31, 2018 at 1:34 PM
    #890
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Get a Instagram. Posted a run video up there
    StOrMyThEtAcO and MarX like this.
  11. Mar 31, 2018 at 2:09 PM
    #891
    ThomasMore66
    Ooo. I followed you there. Don’t check it very often.
    DOUBLLD[QUOTED][OP] likes this.
  12. Mar 31, 2018 at 2:43 PM
    #892
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Like a dyno run? I don't see it on insta
  13. Mar 31, 2018 at 2:48 PM
    #893
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    My Instagram story.
    MarX likes this.
  14. Mar 31, 2018 at 2:48 PM
    #894
    Iamraiderpower
    Iamraiderpower Well-Known Member
    What about us no instafacesnaptwit people?
    BYJOSHCOOK, Torspd, TacoCat and 3 others like this.
  15. Mar 31, 2018 at 2:52 PM
    #895
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Ahh there it is. Get that thing broken in and bump up the boost! Needs more power
  16. Mar 31, 2018 at 2:56 PM
    #896
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    He posted a video of a dyno run with 636 hp. Vids look badass too.
    DOUBLLD[OP] likes this.
  17. Mar 31, 2018 at 2:57 PM
    #897
    Iamraiderpower
    Telling me about that is like describing a video on the radio :bananadead::D
    Martyinco, Torspd, TacoCat and 3 others like this.
  18. Mar 31, 2018 at 3:04 PM
    #898
    yota243
    E.J.
    north Alabama
    I cant figure out how to listen to it...
  19. Mar 31, 2018 at 3:05 PM
    #899
    Iamraiderpower
    Turn up your volume, duh :D
    StOrMyThEtAcO likes this.
  20. Mar 31, 2018 at 3:07 PM
    #900
    yota243
    E.J.
    north Alabama
    Like its not in his post vids its on his profile and when you tap it it just goes to the next pic or vid:bananadead:
