DOUBLLDS JUGGERNAUT LS TWIN TURBO TACO
Discussion in '2nd Gen. Builds (2005-2015)' started by DOUBLLD, Oct 24, 2016.
  1. Apr 23, 2018 at 9:54 AM
    #961
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Are they upgraded rockers, or OEM
  2. Apr 23, 2018 at 10:13 AM
    #962
    DOUBLLD
    DOUBLLD [OP] Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    The ones that broke roller rockers. Now I'm getting shaft mounted roller rockers
    MarX and ChadsPride like this.
  3. Apr 23, 2018 at 10:42 AM
    #963
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Gotcha
  4. Apr 25, 2018 at 9:18 AM
    #964
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Well replaced the rockers last night all is good. Ive been battling valve cover leaks due to the design. It uses a flat gasket instead of the oem rubber oring. I found some cork and thought id give it a shot. All was good until i test drove it this morning. I contacted the company and have a solution. I will try and reseal them this afternoon once and for all lol.
    MarX and buyobuyo like this.
  5. Apr 25, 2018 at 9:47 AM
    #965
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Too much Powa for the seals! :D
    Back to roasting rubbers, eh?
  6. Apr 25, 2018 at 9:49 AM
    #966
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Yes sir. Had the truck outside and it rained so i had to get the wastegates to open to get all the water out so did a short full throttle pull this morning.
    MarX, 05Taco4x4 and buyobuyo like this.
  7. Apr 25, 2018 at 9:52 AM
    #967
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Giggity
    BassAckwards, TacoCat and ChadsPride like this.
  8. May 11, 2018 at 8:56 AM
    #968
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    So I know I have not posted much. I recently had my torque converter take a crap on me. I placed a order for a full billet unit from Neil chance. It is rated for 4k hp. I hope I cant break this one. The last one was from Monster transmission which lasted only about a month LOL. So much for there "thor" unit being able to handle 1k wheel. Anyway the transmission is getting check as well to make sure all is ok. Converter should be here next week and ill get it all back together and hope for no more issues.
    MarX, Toyko Joe, boogie3478 and 5 others like this.
  9. May 11, 2018 at 9:47 AM
    #969
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Did you let Monster know about their failed product?
    Torspd and ChadsPride like this.
  10. May 11, 2018 at 11:05 AM
    #970
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Yes since it's over a year they can't do anything even though I had to send it back twice for them to fix it .it wouldn't even install all the way into the pump in the transmission. I asked if that was taken into account sorry we can't do anything sir. So I move on with a better company and get it running right again.
    MarX, Toyko Joe, TacoCat and 2 others like this.
  11. May 11, 2018 at 11:12 AM
    #971
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I would say "Next Company." "Better" will be once it proves to last.
  12. May 11, 2018 at 12:30 PM
    #972
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Well the converter they are making for me is the same one that was used the pro mod that broke the record..
  13. Jul 16, 2018 at 8:59 AM
    #973
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    Well trans has been back in the truck for a few weeks now. Everything is running and driving great. Nothing really to be said other than im enjoying it and driving it when I can.
  14. Jul 16, 2018 at 9:02 AM
    #974
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Well that's just boring. :boink: :cookiemonster:
    Glad to hear though.
    Now go make an exciting video!!!!:burnrubber:
  15. Jul 16, 2018 at 9:12 AM
    #975
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    I have a photo shoot tomorrow maybe have a cool video as well.
  16. Jul 16, 2018 at 9:16 AM
    #976
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Been spying on instagram... :spy:
    ChadsPride likes this.
  17. Jul 16, 2018 at 9:59 AM
    #977
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    That is where most of my posting is.
    MarX and HomerTaco[QUOTED] like this.
  18. Jul 17, 2018 at 7:04 PM
    #978
    AKSig88
    AKSig88 Well-Known Member
    Ann Arbor, MI
    2023 SR5 Tundra
    That makes two of us.....:spy::spy:
  19. Aug 25, 2018 at 8:21 PM
    #979
    Shabutie
    Shabutie Well-Known Member
    Zach
    Fort Stewart
    2002 Toyota Tacoma Limited 4WD 4dr
    subbed as fuuuuck
  20. Aug 25, 2018 at 8:43 PM
    #980
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
