Doug Thorley 2.7 Headers
Discussion in 'Performance and Tuning' started by Gusfco, May 15, 2017.
  1. Sep 5, 2017 at 11:47 AM
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    That's where I installed mine, and I had no issues at all. 3 years in california with it on, no issues anywhere with visual or actual emissions testing.
    I do hope you find a fix for your header. All bs aside, I just wish the best for everyone, and your thought about checking out the flange is a good start at this point.
  2. Sep 5, 2017 at 11:55 AM
    JohnGee
    JohnGee Member
    2014 White extended 5 Lug
    WOW! I would like That!! if I can not fix the CEL I may swap it out......
  3. Sep 16, 2019 at 6:00 PM
    Thecsoup
    Thecsoup New Member
    Nathan
    2014 4x4 2.7lt reaper build
    AFE Machforce-xp stainless catback exhaust Magnum force stage 2 so cold air intake Doug Thorley headers 4-2-1 tri-y exhaust
    Hey man I'm just about to install these and the install instructions states to use high temp bead of silicon , did you use that or did you find a gasket for it
  4. Jun 1, 2022 at 8:20 PM
    taco4pot
    taco4pot Member
    Beaumont Ca
    2013 Tacoma Access cab prerunner 2.7
    I hate to bring these old posts back from the dead, BUT..... did you ever figure out what was causing the p2441? I installed my DT header about a month go and I am throwing that pending code every other day. I hate to have to scrap that header.
