Doug Thorley Headers
Discussion in 'Performance and Tuning' started by aoehrle11, Jan 28, 2009.
  1. Jan 28, 2009 at 12:39 PM
    aoehrle11
    aoehrle11 [OP] Well-Known Member
    Drew
    Philadelphia
    3 inch Pro Comp lift,K&N Intake, Flowmaster cat back exhaust/ Grillecraft mesh grill (upper and lower), Light bar behind grille, Gibson intercooled tips, Go Rhino dominator 2 nerf bars, Mag lite mod.
    What in addition to the headers and a flowmaster cat back exhaust do I need to bring to the muffler shop? How many and what kind of high flow catalytic converters do I need?
  2. Jan 28, 2009 at 12:42 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    02 simulator so ur dont throw a CEL code
  3. Jan 28, 2009 at 12:43 PM
    tacoskim
    Los Angeles, CA
    Stock
    and for your cats, ur gonna get rid of the 1st set with ur long tubes, youll still have the 2 reat cats in the stock y-pipe that u should just leave alone unless u like the sound of just stupid loud then get rid of all 4 cats
  4. Jan 28, 2009 at 1:31 PM
    Neubs
    Neubs Sold my Tacoma. Goodbye TW.
    Maryland
    06 TRD Offroad DC 4X4
    ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | OME Darkar Leaf Springs | 5150 10" Bilstein Rear Shocks| Light Racing UCAs | All Pro U-Bolt Flip Kit | Timbren Rear Bumps | Extended Stainless Steel Rear Brake Lines | ARB CKMA12 On-Board Air Compressor | Method 16" Race Wheels | Goodyear 285/70/16 MTR | 48" Hi-Lift Jack | ToyTec Diff Drop | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Intense White Bulbs | PIAA Silicone Wipers | Toyota Bed Mat |Sockmonkey Graphics | 20% Tint | Sport Hood | Scan Gauge II & Blend Mount | Shrockworks Sliders | ARB Bumper | Warn M8000 Winch | Viking Synthetic Winch line | 12-Volt Guy In-Dash Winch Controller | Viking Delrin Rollers | Daystar Winch Isolator| ARB/IPF 900XS Lights | Weather Tech Liners | Rock Lights | Diff Breather Mod | Extra Bed D-Rings | Misc. LED bulbs throughout
    Sorry for the simple question but will our trucks pass emissions with only one set of cats?
  5. Jan 28, 2009 at 1:46 PM
    aoehrle11
    Drew
    Philadelphia
    Does the o2 sensor have to be eliminated? And currently its setup with the cats on the ends of both manifolds, the whole system is gona be attached to a flowmaster cat back system, where should the new cats be positioned? When the headers come off the engine it should be going into a single pipe should it not? And arent the doug thorley headers shortys only?
  6. Jan 28, 2009 at 1:48 PM
    tacoskim
    Los Angeles, CA
    Stock
    k ur headers are gonna connect to a y-pipe, then ur y-pipe is what is gonna connect to ur flowmaster cat back system, ur still gonna have ur stock y-pipe which has the 2 rear cats.... the 02 simulator is some wiring so u dont get an CEL. u dont have to install it, but its a good idea to
  7. Jan 28, 2009 at 1:49 PM
    tacoskim
    Los Angeles, CA
    Stock
    depends what ur emissions are like. if they sniff then ur not gonna pass with no cats. if they visual then u can get away with it if u have ur rear cats or the pipe bomb with resonators that kinda look like cats
  8. Jan 28, 2009 at 1:56 PM
    aoehrle11
    Drew
    Philadelphia
    The headers come with o2 sensor hole. So wouldn't I just have to put my stock sensor in the header?
  9. Jan 28, 2009 at 1:59 PM
    Neubs
    Maryland
    Thanks for the reply, under a sniff test, will it pass with only the rear cats? Prob not?
  10. Jan 28, 2009 at 2:02 PM
    tacoskim
    Los Angeles, CA
    Stock
    probably not. ur first pair of cats do most of all the work anyways. youll have a better chance passing with only front cats compared to only havin rear cats. i still have my front but canceled out my rear. but before emissions ill just put the stock y-pipe back on to pass the sniff, shouldn take long.
  11. Jan 28, 2009 at 2:04 PM
    tacoskim
    Los Angeles, CA
    Stock
  12. Jan 28, 2009 at 2:04 PM
    aoehrle11
    Drew
    Philadelphia
    Im trying to get an idea of how to lay this out because the muffler shop cant spend time finding parts to install. The current exhaust manifolds come off of the engine and right down into cats, now the doug thorley headers look like this...
    and the stock manifold with cats look like this, and on both sides im seeing cats coming off the manifold, then connect to the y pipe, my question is what do i need to replace these with in terms of high flow cats, and will any other pipes be required?
  13. Jan 28, 2009 at 2:07 PM
    tacoskim
    Los Angeles, CA
    Stock
    oh ok so your gettin the short tubes?!?!?!?! thats gonna cost more to install cuz ur gonna have to take out the header, weld to cat, then put back on, then back off, then back on. i thought u were gettin the long tubes which is easier of an install. with ur set up u will still have all 4 cats. make sure the shop is a reputable one cuz if they mess up on the weld u can have some crappy leaks
  14. Jan 28, 2009 at 2:08 PM
    tacoskim
    Los Angeles, CA
    Stock
    and u do not need high flow cats, not worth the money nor the labor
  15. Jan 28, 2009 at 2:08 PM
    aoehrle11
    Drew
    Philadelphia
    I know that I will have all 4 cats, I'm asking what kind I am going to need?
  16. Jan 28, 2009 at 2:10 PM
    tacoskim
    Los Angeles, CA
    Stock
    ur still gonna use your stock cats. just show up to the muffler shop with everything in the box and ur fine. i think the dt shorties used the regular gasket so u dont need to get that one.
  17. Jan 28, 2009 at 2:13 PM
    aoehrle11
    Drew
    Philadelphia
    Assuming i wanted to replaced the cats, or had to, im just concerned about the length of the cat and passing emissions, thats what im unsure of. I can get two catco universal cats for 30 each thats not a problem, the problem is what is the correct length of the cat so that it does pass emissions.
  18. Jan 28, 2009 at 2:14 PM
    tacoskim
    Los Angeles, CA
    Stock
    dude save your money!! the headers are made specifically for you to weld the stock cats to them so u dont have to worry about the length. u will still have all 4 cats so u will pass emissions!! dont worry!
  19. Jan 28, 2009 at 2:36 PM
    aoehrle11
    Drew
    Philadelphia
    well there isnt 4 cats on there now anyway, only two, here let me show you how its setup...
    this is judging strictly by what i can see under the car, now the muffler shop will use the existing cats but the price could be raised due to the fact that it requires more work to cut them off and fix the ends for welding given the fact that they are rusted up so bad, im not so much concerned about the money factor if it involves it being done the right way so it can last, i dont want the shop to try to weld on a rusted cat and it start leaking a few days later.
    In addition to the headers being installed i also have the flowmaster cat back exhaust which is shown here...
  20. Jan 28, 2009 at 2:47 PM
    tacoskim
    Los Angeles, CA
    Stock
    k ur not makin any sense, im sorry. all of our trucks have 4 cats. two connected to ur manifold, then two are on ur y-pipe. ur drawing is missing a set. unless u have an aftermarket y-pipe that u didnt tell us about . go under truck and take a pic if u can
