doug thorley long tube headers question
Discussion in 'Performance and Tuning' started by Joeymgd78, Jan 4, 2012.
  1. Jul 27, 2012 at 12:58 PM
    Jughead
    Jughead Well-Known Member
    Aaron
    Moreno Valley, CA
    07 Taco access cab
    AEM bruteforce cold air intake. doug thorley headers. flowmaster exhaust. HID kit heads and fogs. "Taco" badges. black vinyl roof. plastidipped grill and rear bumper and 3rd brakelight. headlight mod. 7" alpine touchscreen head unit. JL audio door components. 10" L7 kicker. custom interior. limo tint all the way around. 50% tint on whole windshield plus 5% sunstrip. pro comp leveling kit in front
    ive never had any problems with heat.
  2. Jul 27, 2012 at 2:11 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Compared to the factory iron log headers (05-08) that is completely incorrect. Less restriction equals less heat. Compared to the stamped steel and angle headers of the 09+ , they should still be a little cooler. A laser temp gun would really be able to tell you, if someone setup a side by side experiment.
  3. Jul 2, 2015 at 4:27 PM
    Tyson
    Tyson $Mr.T$
    Tyson
    Wyoming
    15' TRD off road, dbl, 6spd, 4.0L
    All-Pro UCA Stage 4 Icon lift redline hood struts interior dome and map LED lights 2 spot led pods (ditch lights) flush mount rear back up flood pods hood and bed LED lights GPS anytime mod RTMR electrical system (relays fuses etc.) weather tech floor mats anytime fog lights bixenon headlights and fogs ABS off switch anytime rear e-locker 30" OSRAM light bar (in grill) ARB CKMTA12 compressor ARB front locker Rock sliders all-pro Apex coming later: Doug Thorley long tube headers Y pipe Exhaust
    so exhaust system.... for sure going with the Doug Thorley long tubes,.....
    the question I have is about the Y pipe and exhaust. I just want a good deep throaty sound. (no rice burner, nothing extremely load)...
    what are best options?
  4. Jul 4, 2015 at 11:26 PM
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Would it also pass smog? I always thought it wouldn't.
  5. Jul 5, 2015 at 8:58 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    With DTLT's and the OEM Y-pipe, it will not pass smog.
  6. Jul 5, 2015 at 9:24 AM
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Is it pretty easy to remove and put the stock headers back on to pass?
  7. Jul 5, 2015 at 10:55 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It is for me. If you use antiseize on the hardware. Takes about 30-45 minutes on a pre-air injection year model.
  8. Jul 5, 2015 at 10:56 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Make sure to use copper based antiseize. Otherwise with the silicone based, you run the risk of damaging your sensors.
  9. Jul 5, 2015 at 11:01 AM
    SDB666
    SDB666 Well-Known Member
    Apex, NC
    In CA? You won't get past visual, so you'll never know if it would pass the sniffer.
    In free states? Unless they take tail pipe readings you're fine. Even then you may be able to pass depending on the tune. It wasn't unheard of for catless Subarus to pass emissions if the tech "didn't see" headers, intake, turbos, etc. hahaha.
  10. Jul 5, 2015 at 3:31 PM
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    I think I'm gonna end up going with the short tube, just gonna cost a little more
