Doug Thorley LT headers
Discussion in 'Performance and Tuning' started by TacoMan33, Mar 24, 2016.
  1. Mar 24, 2016 at 10:27 PM
    TacoMan33
    TacoMan33 [OP] The little idiot that could
    David
    Texas
    2006 PreRunner 4.0 V6 SR5 ACLB
    JBA C/B | Apline door speakers | Kenwood radio
    Truck info:
    2006 Tacoma 4.0L V6 PreRunner 2WD
    6-speed Automatic
    140K and runs like new
    I have a JBA catback system showing up tomorrow and I'm ecxited since this will be my first upgrade involving performance. Next thing on my list: getting rid of those nasty looking stock manifolds and get some nice headers.
    I've been considering Doug Thorley long tubes but i have two concerns about getting those that have me wondering if i should look at other headers.
    My first one is this: I know long tube headers means deleting my cats. Should i delete the cats, and if so, how do I pass visual inspection? I live in Texas so I'm not worried about emmisions tests, just visual. Also, is the performance gain worth it?
    Second: would DTLT's combined with a JBA catback be too loud? I've heard audio of the jba's and DT's but not both put together on a taco so im worried about spending hundreds for good performance gains but getting raspy and obnoxious sound.
    Also, are there any Y-pipes with high flow cats? Those would make this decision easier.
    Thank you guys. All comments and suggestions welcome
  2. Mar 24, 2016 at 10:36 PM
    troyb123
    troyb123 Well-Known Member
    Troy
    Lake Stevens, WA
    2014 SR5 DCSB 4X4
    Flowmaster american thunder series exhaust, AEM Brute Force Intake System, Doug Thorley Headers, BPF grille, SCS Stealth 6 wheels.
    The sound of that pair (JBA's with DTLT) would more likely sound pretty decent. I got Doug thorley's shorties paired with flowmasters and it has a deep tone to it. Those LT's are gonna wake up the 4.0L thats for damn sure.
  3. Mar 24, 2016 at 10:41 PM
    TacoMan33
    David
    Texas
    Would you reccomend shorties over LT's or the LT's over shorties. If needed, i can drive 6 hours west to my uncle's shop and weld some stuff if needed so i can make fitment happen
  4. Mar 28, 2016 at 12:16 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I recommend the URD SPEC-U headers. Best performance gain of torque throughout the whole rpm range.
    Springs719 likes this.
  5. Mar 30, 2016 at 11:59 AM
    TacoMan33
    David
    Texas
    Defintely sonething to consider
  6. Mar 30, 2016 at 4:48 PM
    troyb123
    Troy
    Lake Stevens, WA
    2014 SR5 DCSB 4X4
    personally i went with shorties because my taco is my daily but i would prefer the LT's because they would sound nastier than the shorties. But its all up to you my friend, good luck!
  7. Mar 30, 2016 at 9:20 PM
    TacoMan33
    David
    Texas
    Trouble123, where did you get your grille and how much did it cost.
