Doug Thorley Problems
Discussion in '4 Cylinder' started by Bosmob, Jul 3, 2012.
  1. Jul 3, 2012 at 5:42 PM
    Bosmob
    Bosmob [OP] Well-Known Member
    Kevin
    San Diego, CA
    '11 Access Cab SR5 I4 4AT
    Fat Bob's 2.75" front spacers Magnaflow Muffler Doug Thorley Header ImMrYo Mirror Bracket
    Hey I just installed a Doug Thorley header on my 2011.
    I encountered some problems that The Truck Shop in SD helped me out with.
    1. The Air Switching Valve contacts the header air tubes to the point where they are almost one piece and unmovable.
    2. The Intake Pipe Insulator was nowhere near bolt on ready and had to be heated up and bent.
    3. There is an exhaust leak where the Intake Pipe Insulator bolts up to the header but I am going to address that tonight.
    Has anybody else encountered these problems?:confused:
  2. Jul 3, 2012 at 6:03 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    #'s 1 and 2 were problems I had. Had to grind bottom of valve to clear pipe which left a hole that had to be aluminum welded from inside of valve after having to take it apart. I didn't want to heat and bend the air pipe in case it should of weakened and cracked. The brownish goop is where it was touching the underside of valve.
  3. Jul 3, 2012 at 10:17 PM
    Bosmob
    Kevin
    San Diego, CA
    dang Doug Thorley is blowing it!
    The air pipe seemed like it was thick enough to withstand some heat and bending. Mine is going to have to be bent again cause there is a massive gap that was causing the truck to sound like a tractor.
    How did you address #2?
    Did you reuse all the factory gaskets? Did you use copper coat on the big manifold gasket?
  4. Jul 4, 2012 at 7:52 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Perhaps #1 was our only problem but I do recall another slight problem ( i beleive what you are referring to. It was two years ago we installed it ( I can barely remember what I had for breakfast) Yes, we copper gasketed everything with the stock gaskets. [​IMG]
  5. Jul 6, 2012 at 3:41 PM
    Bosmob
    Kevin
    San Diego, CA
    I'm going to have to grind down my air switching valve as well.
    Do you remember how thick the material is before you had to weld it?
  6. Jul 6, 2012 at 3:44 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    .... y not just return it to DT n tell them of ur problems??? y ruin a perfectly good set of headers n have to hack up ur shit to get'em to fit?? if it was me, id send them back, tell DT to do more R&D n get that shit right! IMO. when i put mines on, only thing i had to "fab" was i stacked washers for spacers onto the mount that holds the header in location from the tranny.
  7. Jul 6, 2012 at 4:07 PM
    Bosmob
    Kevin
    San Diego, CA
    I bought the headers through a reputible local shop. The owner said the Doug Thorley isn't very good to deal with and every header his shop installs has to be modified to fit. We already modified the air pipe to fit but the header cannot seal tightly against the head because the air switching valve.
    I highly doubt that Doug Thorley will be of any assistance but I will try.
  8. Jul 11, 2012 at 1:26 PM
    tacobo670
    Ray
    Las Vegas
    O well, already started cutting huh? Can't go back now! Lol
  9. Jul 19, 2012 at 1:47 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    This is new to me ,have not read anything bad about DTs for the older 4bangers.
    Was planning on getting some soon since lce stop making pipes for mine.
  10. Jul 19, 2012 at 7:57 AM
    BlackSeven
    BlackSeven Well-Known Member
    Maryland
    2017 4cyl 5 spd 4x4 extended cab
    Toytec Ultimate Lift kit, Toytec Rear AAL, 4.88 Gears, ARB Rear locker, Doug Thorley header, Volant Cold Air Intake, Demello Offroad front high clearance bumper, ARB On board Air compressor, BLHM, Wet Okoles, 2011 Color matched grill, Weathertech mats, 4x Innovations Sliders, ATO Engine Skid plate, ATO High lift bed mounts.
    I can honestly say I had no problems aside from one of the bolts from the header to the cat pipe being frozen and having to cut it off (with only 5000 miles on the truck !?). I honestly felt everything in the kit bolted up and worked really well. I've got about 8k miles on the header and I'm happy.
  11. Sep 16, 2012 at 12:25 AM
    Bosmob
    Kevin
    San Diego, CA
    Well, I returned my 1st header to DT in July, 3 months ago!:mad:
    I received a new one in the mail this week and I just got done installing it. The header bolts up to the head correctly and the Insulator Pipe bolts up to the Air Switching Valve nicely(this was the previous problem). But the midpipe doesn't seal properly with the header. I can feel exhaust gases puffing out through the gap.
    I'm going to try to see what I can do about it tomorrow but DAMN! I'm really despising Doug Thorley right now!
    Has anybody else ran into this problem?
  12. Sep 16, 2012 at 4:50 AM
    BlackSeven
    Maryland
    You need to replace the graphite doughnut gasket inbetween the header and midpipe. This is not included with the header, mine was in good shape so I was able to reuse it. But it does say in the DT install instructions that you may need to buy a new one.
  13. Sep 16, 2012 at 1:02 PM
    Bosmob
    Kevin
    San Diego, CA
    I know that it's probably a good idea to use a new donut but I know that it won't fix the problem. The 2 flanges that meet up aren't equal all the way around. The gap is really tiny on one side and enormous on the other side.
    I tried loosening up the midpipe to the first cat and twisting the midpipe but it wouldn't budge. Then I tried using a jack to support the cat and a pair of vise grips to clamp the flanges together and bolt them down. But as soon as I released the vise grips and jack, the gap opened up again.:mad:
    It is almost like the flange was welded on the header a bit crooked!
    Anybody have any suggestions?
  14. Sep 21, 2012 at 3:45 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Oh dear god, I just got my 2nd one that was shipped with out yours and am installing it tomorrow.......you have me worried already. I will fucking lose my shit if it doesnt fit.
  15. Sep 21, 2012 at 8:38 PM
    Bosmob
    Kevin
    San Diego, CA
    I have removed and installed my exhaust manifold on my truck a total of 7 times already.
    The 3rd header is being sent out to me and I will see if that finally fits. This whole ordeal has taken about 3 months.
  16. Sep 22, 2012 at 4:49 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    I know what yyou mean. I originally ordered my header in March
  17. Feb 12, 2016 at 4:18 PM
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    3.5 hours of work and this is what Dough Thorley Header looks like. Ended up taking it to a muffler shop. They welded the catalytic converter pipe directly to the header flange. Shot a picture to D.T. they didn't even apologize, just inform me I had voided my warranty due to alternation.
  18. Feb 12, 2016 at 4:21 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Fack, one more reason to not buy those for my truck.
  19. Feb 12, 2016 at 4:22 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    What a bunch of dicks form DT for not even apologizing for their shitty craftsmanship. Though
    billybob50 likes this.
  20. Feb 15, 2016 at 7:12 PM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    Sorry Doug Thorley sucks so bad. That's why I hate aftermarket junk.
