Doug Thorley Y pipe bomb?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1tacoplease, May 20, 2014.
  1. May 20, 2014 at 7:21 PM
    1tacoplease
    1tacoplease [OP] I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    Has anyone used this Y pipe? Does it eliminate rasp? Is it too loud? Notice any gains? Thanks in advance.
  2. May 21, 2014 at 5:02 PM
    1tacoplease
    Temecula
  3. May 21, 2014 at 5:05 PM
    fyremanpat
    fyremanpat Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    increases rasp due to deleting the factory resonators
  4. May 21, 2014 at 5:38 PM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Deletes the secondary cats, not resonators :)
  5. May 21, 2014 at 6:15 PM
    BLOODYMARY
    BLOODYMARY Well-Known Member
    Keith
    Tulsa, OK
    2012 Tacoma Double
    AFE Exhaust, AFE Panel Filter
    I had it, now went back to stock y-pipe with secondary cat delete and like it better and more cost effective.
  6. May 21, 2014 at 6:49 PM
    MadToy
    Nick
    Huntersville, NC
    I did the DT pipe solely for clearance. The stock pipe got hung up on rocks every trip off road. I added an ultra quiet Vibrant resonator and it's as quiet as stock.
  7. May 22, 2014 at 2:05 PM
    fyremanpat
    Pat
    757
    why do people keep calling them secondary cats? theyre not catalytic converters, theyre resonators! try putting your downstream o2 sensor behind one and see what happens.
    t.hornstra likes this.
  8. May 22, 2014 at 3:51 PM
    S1000RR
    S1000RR Well-Known Member
    2013 TRD Supercharged Sport
    I'm running the URD Y Pipes and they sound sweet. They really open up the TRD exhaust.
  9. May 22, 2014 at 4:29 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The emissions sticker basically mentions them as cats. So that the truck can qualify for the Ultra high emissions standards. If you cut them apart though, there is only cat material at the inlet and outlet. Nothing in between. So it essentially both. + or -
  10. May 22, 2014 at 6:30 PM
    MadToy
    Nick
    Huntersville, NC
    Because they are catalytic converters.
    High flow cats will trip o2 codes too, but they're still cats, not resonators.
  11. May 22, 2014 at 7:11 PM
    BLOODYMARY
    Keith
    Tulsa, OK
    2012 Tacoma Double
    ^ True Statement
  12. May 23, 2014 at 3:57 AM
    fyremanpat
    Pat
    757
    I have a hi flow on my car that doesnt throw a CEL...ive had several vehicles with hi flow cats that never threw CEL's
  13. May 23, 2014 at 4:27 AM
    MadToy
    Nick
    Huntersville, NC
    Depends on the cat and car. Some do, some don't. But regardless, the secondaries on the Tacoma are converters, not resonators. So that's why so many people here call them cats.
  14. May 23, 2014 at 11:29 AM
    1tacoplease
    Temecula
    Well, I bought the DT y pipe bomb and am going that route. Hopefully I see some gains.
  15. May 23, 2014 at 11:40 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Yes for years.
    No.
    No.
    No.
    I suggest you install some sort of heat shielding so you don't cook your 4x4 actuator on the transfer-case. The DT Y pipe runs a little to close to it to leave it without a heat barrier in my opinion.
    bad angle on the pic, but you can get what I'm talking about.
  16. May 23, 2014 at 11:47 AM
    MadToy
    Nick
    Huntersville, NC
    Agree with the above. Do it for clearance, and maybe a change in sound, but you won't see any performance gains.
    Looks like you also run the Vibrant :). Best money I've spent! (Not really, but definitely well spent)
  17. May 23, 2014 at 11:49 AM
    XXXX
    sKiP
    05 Prius
    Stock pic from Google.
    My pig looks nothing like that. I use my truck offroad so everything is rusted and covered in scrapes.
  18. May 23, 2014 at 12:43 PM
    1tacoplease
    Temecula
  19. May 23, 2014 at 12:51 PM
    XXXX
    sKiP
    05 Prius
    I wouldn't buy that, but to each their own. I'm sure it's great, but dam expensive.
    I bought a roll of lava wrap years ago and had some left over from a project so I used that.
    similar to this stuff.....
    you wet it, install it, clamp it, let it dry, then spray it.
    wrap the pipe where it gets close to the plastic actuator on the transfer case. Thats about as specific as one can get.
  20. May 23, 2014 at 12:58 PM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
