Doug Thorley Y-pipe problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by carolinataco, May 5, 2010.
  1. May 5, 2010 at 3:16 PM
    carolinataco
    carolinataco [OP] Well-Known Member
    I just installed my doug thorley y-pipe and it leaks from the passenger side flange. the bottome of the flange sealed up fine but at the top there is a gap. I tried to bend it up with a floor jack but that did not help. I emailed DT but they have been no help yet, when i call no answer. Any ideas/suggestions?
  2. May 5, 2010 at 3:21 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    Yeah, it seems the majority need to help it fit properly..
  3. May 5, 2010 at 3:22 PM
    carolinataco
    Yea it leaks BAD
  4. May 5, 2010 at 3:25 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    maybe muffler patch, or high temp silicon sealer. thats what i use for the headers on my bikes?
  5. May 5, 2010 at 3:26 PM
    carolinataco
    Yea, I want that to be my last resort though. I tried some ultra black i had layin around but that didnt work.
  6. May 5, 2010 at 6:29 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Was there a stock gasket you could reuse?
  7. May 5, 2010 at 6:33 PM
    carolinataco
    No you have to buy new ones because they are crush gaskets
  8. May 5, 2010 at 8:55 PM
    Jap
    Jap Loving this
    TRD supercharger, extractors, 7 psi pulley, Interceptor ECU
    Has this been resolved?
    You put a new spiral wound gasket in there?
    They do not need sealant if set up right.
    I'm guessing there is gasket problems or the flange has warped during manufacture.
    For the record, I HATE. yes, HATE, 2 bolt flanges.
    I use 4 bolt on all my systems. they are neater and seal first time, everytime.
