down hill assist questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by malcolm31, Aug 5, 2010.
  1. Aug 5, 2010 at 9:35 AM
    malcolm31
    malcolm31 [OP] New Member
    PA
    09 DC SR5
    i have a 2009 tacoma DC v6 automatic transmission. I am assuming this is the downhill assist, but whatever it is it really seems to kick in going down steep (and even not so steep) grades. I am guessing this lurching is the truck downshifting. I found this great when I was hauling our 1100 pound camper in the rocky mtns., in fact I didn't even notice the lurching then, but it seems excessive when I am not hauling or towing anything. I also notice the truck revs when I make a turn onto a straight or level road after going down hill. Is this normal?
  2. Aug 5, 2010 at 9:49 AM
    DevL
    DevL Well-Known Member
    DAC is a series of intermittent brake pulses (kind of ABS feeling) and only works in 4L. There is no mistaking it. It keeps you at 3 mph on steep down slopes.
  3. Aug 5, 2010 at 1:59 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    do you have the downhill assist on a SR5? I dont
    i think its just the way the automatic transmission works
  4. Aug 5, 2010 at 2:05 PM
    skistoy
    Western New York
    thought so , but didnt want to engage foot before doublechecking - haha
    Hey malcolm31 , welcome to the sight
    hold on to the wallet, the more you read and learn about
    the harder it gets to hold on the money.
    But you'll learn a great deal here.
    lets see some pic's of the truck
  5. Aug 5, 2010 at 6:25 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    x2 :)
  6. Aug 5, 2010 at 6:32 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    yep, it'll also hold gear when going up hills as well
  7. Aug 6, 2010 at 9:39 AM
    DevL
    Have you had it work going uphill? I was on a 45 degree incline the other day and in 4L with my locker on (deactivates DAC) my truck didnt move with no throttle... I have only felt DAC a couple of times but never felt any hill start control... how do you know its working (manual says it uses brakes to hold you till you apply throttle for a maximum of 5 seconds)?
  8. Aug 6, 2010 at 12:41 PM
    CopDoctor
    08 335i
    no i mean when you're going up a hill, like a mountain pass, it will hold your gear so it's not hunting all over the place.
  9. Aug 6, 2010 at 12:51 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Your transmission works like that because we don't have a tow/haul button on the Tacoma's. It's basically in that mode all the time so the transmission holds you back on steep downhill grades and holds a gear going uphill. Mine does the same thing, including the higher revving once you go to a flat section after a hill.
  10. Aug 6, 2010 at 1:13 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Hmmm. Mine doesn't engine brake at all. If I'm heading downhill with no throttle, it's basically free coast.
    As for DAC in 4L ... when you have it on, you can't mistake it. LOL it sounds like your truck is falling apart ... almost a grinding type noise.
  11. Aug 6, 2010 at 5:41 PM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    I agree with Pugga that it is built into the truck for towing.
    I have felt it in my 10 DC. It really depends on the road and your style if you will encounter it or not, but I have a particular curve going down a mountain and when I apply the brake for a few seconds, the truck always downshifts. Then it holds that gear until I apply a little gas and it bumps back up a gear. I have approached it a little more aggressive a few times to see how it reacts and it can be a completely different response from the truck.
