Down shifting an automatic
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jake1530, Mar 6, 2016.
  1. Mar 6, 2016 at 9:15 AM
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    2021 TRD PRO 6MT Midnight Black
    I downshift all the time. Nothing crazy, though. Like others have stated, be mindful of your engine speed.
    Dagosa likes this.
  2. Mar 6, 2016 at 9:19 AM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    When I do much braking at that speed, it downshifts automatically to 4 . I see nothing wrong with that. If you did it preemptively and the RPMS are below 3000 or so, what's the problem. Btw, in town, I shift immediately to 4 for speeds less then 35-45 mph. My wife's six speed auto, similar to a 3 r gen Taco trans, we do the same thing. Town driving means, into S mode which defaults to 4 th before you change gears.
  3. Mar 6, 2016 at 10:21 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I was taught to recognize inexperienced mountain drivers by watching their brake lights. Downshifting on steep hills is necessary to avoid brake problems. The last automatic transmission I had was on a T100. At 130 kmiles the brakes were still less than half worn, with lots of mountain driving.
    Tom Servo likes this.
  4. Mar 6, 2016 at 12:20 PM
    gimmeajo
    gimmeajo i'm here for the food
    Zander
    New Orleans via New England
    '13 DCSB 4WD TRD OR
    OME 883, N140, N182, 265/75/16 Hankook ATMs, Weathertechs, chop front flaps, diff breather, killed seatbelt dinger
    I do it often, mostly just to 4 (coming off interstate ramps, cornering, passing quickly) the truck will corner and go if YOU can. 3 if I'm going slower.
    Dagosa likes this.
  5. Mar 6, 2016 at 12:33 PM
    723rdCAT
    723rdCAT Well-Known Member
    Kentucky
    15 SR5 4x4 access cab mgm
    You can put it in any gear you want to use engine braking. If you look in the manual there is a chart showing the top speeds for each gear for both the manual and automatic. Just don't go from 4D to 2 if tour going above the maximum speed for 2nd gear. Look at the chart in the manual then refer to the speed you want to go while going down a hill select the gear that matches the speed you want go. Then the engine will do most of the breaking and you won't need to use your foot brake much if at all.
  6. Mar 6, 2016 at 12:45 PM
    723rdCAT
    Kentucky
    Section 2-1
    2WD 5 speed
    4 to 3 81MPH
    3 to 2 56
    2 to L 22
    4WD 5 speed
    Same as above unless in 4Lo
    in which case RTFM if you have a 4 banger RTFM.
    So on a steep hill if you want to stay below 55 use 2 you will be good and should hardly need the foot brake at all.
    Its on page 136 for the 2015 manual .
  7. Mar 6, 2016 at 1:01 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    If your max rpm is too high the truck won't let it shift down , for example 4 to L
  8. Mar 6, 2016 at 1:07 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    exactly.
    You could be going 80mph and put it in L (1st gear) and it MIGHT go down to 3rd.... the trans has measures to protect itself. I use my gears all the time when doing long grades.... its MUCH better than burning up your brakes and its also much safer as you will actually have brakes to stop if there is an emergency.
    gimmeajo likes this.
  9. Mar 6, 2016 at 1:24 PM
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Though I agree with preemptively downshifting for long hills, I use Cruise control so much along with just touching the brake at times and the truck downshifts at least to fourth itself. That is does, is just a reaffirmation that down shifting is more acceptable then the old argument. " it's better to replace your brakes then your transmission." Toyota cars and trucks downshift by themselves at least one gear for engine braking except in town driving and lower speeds, all the time.
  10. Mar 6, 2016 at 1:37 PM
    Tom Servo
    Tom Servo Dickweed
    Thornton, CO
    2013 DCSB TRD Sport
    Totally agree. I have seen this many times following inexperienced drivers in the mountains of CO. I'll be cruising down hill at 65mph in 4th gear barely ever touching my brakes, while some folks are riding the brakes all the way down.
  11. Mar 6, 2016 at 2:30 PM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    I just got back from a mountain trip and would like to share my 2 cents. I treated big long steep inclines like I was towing. Put it in 4 so the transmission didn't have to constantly go back and forth. As far as declines are concerned I used mainly brakes but the declines weren't bad. A good rule to live by though is brakes are cheap, engines are expensive.
  12. Mar 6, 2016 at 2:44 PM
    2nd screen name
    2nd screen name Tacodelaplaya
    Bob
    LV/SD
    06 AC Sport Prerunner
    Front: Maxtrac, DK heim UCA, 6112 Rear: AP expos, Fox 2.5 RR DSC Fn fivestar with General reds
    Hope you can use that engine to power over through a corner when the breaks are too faded to help...
    Proper engine breaking is the norm. people using the brakes to control speed is a new thing. Think about driving a semi back in the day with drums all around...
  13. Mar 6, 2016 at 3:06 PM
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Old, old, old wives tale. All Toyotas use their computer controlled downshift to engine brake automatically. Put your cuise control on...step on your brake comming down from highway speeds on the interstate to an off ramp. Your Toyota downshifts automatically. Just because you did it preemptively does not mean the Toyota would not do it alone if you didn't.
  14. Mar 7, 2016 at 5:28 AM
    R0dzilla75
    Rodney
    Virginia
    05 Sport
    Also worth noting is I've upgraded my rotors and pads to ebc slotted. It's supposed to help dissipate heat better. As I stated we are talking about the Appalachia mountains not the Rockies. Declines weren't steep and my vehicles not 15000 lbs.
  15. Mar 7, 2016 at 6:03 AM
    #35
    Flannel_Lover
    Flannel_Lover Your resident questionable advice giver
    Lucas
    Greenville, IN
    2011 sclb base 4x4
    Alpine component speakers Rockford Fosgate 10" sub Pioneer DEH-X6800BT Kicker CX 300W amp Extang Trifecta Big Country Brush Guard
    It shouldn't hurt a thing when being smart about it, many times I have downshifted when towing, and hauling. Mines a 4cyl auto (4 speed) I've run down the interstate cooking at 70, engine up around 3500- 4 grand. In the family truck, (2005 Suburban 1500) we were going over mt. Eagle. Going down, shifted it into 3rd, taped the breaks every couple hundred feet, no problems.
