Down side to supercharger
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jayestaco, Jun 29, 2011.
  1. Jun 29, 2011 at 1:04 PM
    jayestaco
    jayestaco [OP] Member
    cincinnati, ohio
    2011 TRD off road
    cargo divider, running boards
    I am seriously considering a TRD SC for my 2011 TRD OR and was wondering if noise was a problem? I have driven older street rods with SCs and most produced a noticable whine at idle which got louder on accleration. Does the TRD SC make alot of noise? My second concern is engine and trans life. A few people have told me not to expect long engine or trans life when using a SC. This is important to me because I generally run my Tacomas 200k or better before I resell them. Any thoughts or suggestions would be greatly appreciated. Also, is there any recommended breakin time on a new engine & trans before installing the SC, I have only 3000 mile on the new truck. thanks!
  2. Jun 29, 2011 at 1:08 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    It's a little hard to get the smile off my face, once I get home.
  3. Jun 29, 2011 at 1:11 PM
    jayestaco
    cincinnati, ohio
    2011 TRD off road
    Can the SC be run on 87 or 89 octane without damage? 93 or better is hard to come by out in the sticks.
  4. Jun 29, 2011 at 1:15 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    ^^^^this^^^^
    it is a must... Trust me.
  5. Jun 29, 2011 at 4:00 PM
    JAB1962
    JAB1962 Member
    DOVER DELAWARE
    2011 SPEEDWAY BLUE TACOMA SPORT DOUBLE CAB LB
    How long of engine life would you expect to see with a supercharger
  6. Jun 29, 2011 at 4:12 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    if you dont dog it from every stop, then it will last a while. only premium gas or better. and if you have the automatic dont worry too much, if you have the standard then good luck. im n/a and my transmission is garbage.
  7. Jun 29, 2011 at 4:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I beat my first gen, SC'd truck like it owed me money, for 100K+ miles, and never an issue. Last I saw it, it was pushing 160K miles, and still no issues. As long as your not running gobs of boost, you shouldnt have any longevity issues.
  8. Jun 29, 2011 at 4:27 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Most don't have a problem, even if you mod it up with pulleys, tuning, exhaust, etc but thats just on the engine. Only bad things that I have seen with the TRD unit is that when the intercooler pumps fails or has a bad connection. And yes maintenance should always be a top priority both n/a and boosted but you'll just have to change out the oil in the supercharger (every 100k I believe) and watch you belt. Other than that don't tell me you wouldn't like the roots whine.
  9. Jun 29, 2011 at 5:07 PM
    98_Mud_bug
    lucedale Ms.
    i love that whine. its better than the whoosh from the rotrex in my opinion.
  10. Jun 29, 2011 at 6:14 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I once stupidly put mid-grade fuel in my supercharged 1st gen...:(
    That thing knocked like a persistent Jehova's Witness.... :(
