Down travel limit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Darkgoatracer, Jul 20, 2018.
  1. Jul 20, 2018 at 3:51 PM
    Darkgoatracer
    Darkgoatracer [OP] Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    So guys I've been having some issues with my truck at full droop. It will droop until the uca hits the spring and the cv shaft binds. This wasnt an issue until i cranked the toytecs up, removed the sway bar and got the front end aligned.
    My question is what limits the droop or down travel. The drivers side droops about 3" more than the passenger side, but why? They appear to be perfect mirrors of each other.
  2. Jul 20, 2018 at 3:54 PM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    I don't know but I know there are travel limiting straps.
  3. Jul 20, 2018 at 3:55 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Yeah! That was my plan initially, but now im wondering if something is wrong since the passenger side doesnt have an issue.
  4. Jul 20, 2018 at 3:58 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    The swaybar would limit down travel, but now that it's not on, the suspension has more individual movement side to side than before. But i have no idea why there's such a difference side to side :notsure:
  5. Jul 20, 2018 at 3:59 PM
    KaptainH
    Kris
    Gainesville, GA
    I just realized this isn't a long travel setup.
  6. Jul 20, 2018 at 4:01 PM
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    Looks like the uniball or ball joint in your UCA may be broken or not seated correctly. Something about that joint looks wrong and overextended.
    HCJ, freddy2923 and MolonLabeTaco like this.
  7. Jul 20, 2018 at 4:02 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    That makes since. But im not the only one not running a sway bar. The axle binds to the point where the tire will not spin
  8. Jul 20, 2018 at 4:03 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    I can pull the boot and look
    Edit: there is no unusual movement in any of the parts, checked by me and a local offroad shop
  9. Jul 20, 2018 at 4:05 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    uca bolt looks funky for sure. usually shock is the first thing to bottom out, then uca, then tie rod, cvs, etc
  10. Jul 20, 2018 at 8:16 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    If that's the stock UCA there's something terribly wrong there. It's not supposed to move that much.
    Just to confirm, no top of coil spacer on the truck?
  11. Jul 20, 2018 at 8:30 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I have less than .25" of difference between PS & DS droop. They both droop, from resting height (tires on the ground to tires just leaving the ground) ~3" since my C/O's are cranked way up. For you to have a 3" difference from one side to the other is a huge issue.
  12. Jul 20, 2018 at 8:40 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Looks like you need some taller steering knuckles
    Darkgoatracer[OP] likes this.
  13. Jul 20, 2018 at 8:40 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    Looking again, it looks like you have a shitload of pre-load on the coils. you can use a tape measurer and measure the exposed threads from the bottom side of the spring pearch to the top edge of the flange where the threads start. Typically if you double that measurement, that is the amount of lift that you have.
  14. Jul 20, 2018 at 8:45 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    First I've ever heard this. I have 2.35" pre-load & 2.5" of lift. Certainly doesn't work for me!
  15. Jul 20, 2018 at 9:02 PM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    Well, actually.... I've heard that, but i don't have adjustable shock perches that are adjusted with a spanner wrench :anonymous:
    still looks like a shitload of pre-load to me though.
  16. Jul 20, 2018 at 9:07 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Lot of bad info in here.
    Your shock (coilover) is toast.
    Those 5100s have a little internal down travel limiter welded on the shaft, which you've broke. You should be able to see the evidence of a couple little tack welds on the shock shaft where it use to reside.
  17. Jul 20, 2018 at 9:11 PM
    08BajaBoy
    08BajaBoy Well-Known Member
    Brian
    Southern Cal
    08 Rugged Trail PreRunner
    AFE Pro Dry S air filter, Magnaflow muffler, FabTech DirtLogic UCA, FabTech 2.5 remote resi (front) and 2.25 remote resi (rear)
    @Darkgoatracer can you post a picture of your passenger side at full droop? It looks like the upper part of the spindle is bent towards the engine bay. Measure the horizontal distance from the face of your wheel spacer to the centerline of the of the UCA ball joint stud for both sides.
  18. Jul 20, 2018 at 10:20 PM
    jafrisi
    jafrisi Well-Known Member
    Tucson, AZ
    14 Superwhite DCSB TRD OR
    Toytec bilstein 5100 lift w AAL. 2.5 front and 1.5 rear. KMC turbine wheels 4.5 bs, BFG KM3s 285/75/16
    I think this may be your problem, unfortunately. It's the only thing that would explain the difference between R and L side.
  19. Jul 21, 2018 at 2:35 AM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    I will try to grab a picture today.
    Ill look for that today
  20. Jul 21, 2018 at 6:48 AM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    @Squeaky Penguin winner winner chicken dinner
