Down travel limit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Darkgoatracer, Jul 20, 2018.
  1. Jul 21, 2018 at 7:34 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Good call! I first suspected the shock was toast but the bottom mount looked ok. I didn't realize it was even possible to break the limiter internally. That's insane. How does that even happen?!!
  2. Jul 21, 2018 at 8:43 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    :thumbsup:
    We'll even I wasn't quite right, because you also managed to break the piston off the shock shaft. You could pick up one 5100 and swap over all the toytec parts, or use it as a good excuse to upgrade to something better.
    Beacuse 5100s... :tinfoilhat:
    ClemsonMGM, DoorDing and TacoCat like this.
  3. Jul 21, 2018 at 11:27 AM
    Darkgoatracer
    Darkgoatracer [OP] Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    Well so now i have question. Can you really on the 5100's belt in limiter to limit down travel? Or should a limiting strap be used? Was mine a fluke or could it happen again?
  4. Jul 21, 2018 at 11:44 AM
    Squeaky Penguin
    Brett
    The correct answer is that if you're going to be topping out your suspension regularly, a limit strap will help prevent shock failure.
    The answer I want to give you is that it wasn't a fluke, 5100s are over-recommended POS shocks, and they'll just fail is some other way even after you strap them. FWIW, here's how the same setup ruined a buddy's trip:
    ChrclTaco likes this.
  5. Jul 21, 2018 at 12:03 PM
    ClemsonMGM
    ClemsonMGM Even Firemen Need Heroes...
    Workin the pole!
    12 Ram 2500
    And that ladies and gents is why forums exist. Problems+forums=solutions
  6. Jul 21, 2018 at 12:11 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    So my next question is can the beefier 6112 be used with the rest of the toytec setup?
  7. Jul 21, 2018 at 12:20 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    A quick search says no. The 6112 is 60mm. More along the lines of the toytec boss coilovers
