"Down Travel"
Discussion in 'Suspension' started by Rucas, Jan 15, 2010.
  1. Jan 15, 2010 at 6:08 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    Billies set to 2.5, is there good enough down travel room? Or over extension of the shock?
    Also will bilstiens fix the taco lean or is that a spring issue?
  2. Jan 15, 2010 at 6:17 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    about 1.5" downtravel. the shocks commercialize themselves as not over extending because the way they are made or something. no they wont fix the lean. you need to put a 1/4" toytec top plate spacer on the driver side to help out with the lean.
  3. Jan 16, 2010 at 1:09 AM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    They must have some sort of top out protection because in order to get 2.5 inches of lift that is a lot of preload on the coil and that would cause a shit ton of rebound force, especially from when the shock is compressed.
    They must have some super super stiff rebound valving.
