Downey/Fabtech 5lug mid travel kit.
Discussion in '5 Lug' started by Tour991, Sep 23, 2017.
  1. Sep 23, 2017 at 8:15 PM
    Tour991
    Tour991 [OP] Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Finally got the lift out from under my truck. Downey lowers and adjustable coil overs, Fabtech uppers and lift spindles. Total lift up to 6.5 inches (will get stiffer as you get higher) I got this lift brand new and have ran it since 2013 less then 50,000 miles on it. Super Rare asking $1,000 shipped.
    trucksig1.jpg 651313113869504730-account_id=1.jpg 4225731636098717468-account_id=1.jpg
    BensYota likes this.
  2. Oct 11, 2017 at 12:31 PM
    Tour991
    James
    South Reno/Tahoe
    Bump!
  3. Oct 21, 2017 at 7:53 PM
    TacoBunny
    TacoBunny Well-Known Member
    AZ
    1997 5 Lug 5VZ
    Would you be willing to sell this without the spindles??
  4. Oct 22, 2017 at 6:48 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    I might be interested in buying the spindles if you buy everything else....
  5. Oct 31, 2017 at 8:02 PM
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    Will you sell just the lowers n coilover
  6. Dec 7, 2017 at 5:53 PM
    Tour991
    James
    South Reno/Tahoe
    Bump upers lowers and coils are still available $650
  7. Dec 14, 2017 at 11:38 PM
    spencerjg72
    spencerjg72 Well-Known Member
    2004 toyota tacoma 5 lug base model
    LCE built motor +40 street piston set Chromoly H-Beam Connecting rods Lightweight flywheel (11lb) 2RZ Head Stage 3 KIt Pro Head stud kit Stage 3 Camshaft set Street Series water pump Adjustable Camgears 2RZFE Flex Fan (16in)
    650 shipped?
  8. Jan 8, 2018 at 5:03 PM
    Tour991
    James
    South Reno/Tahoe
  9. Feb 10, 2018 at 5:20 PM
    Grindmode714
    Grindmode714 Member
    Orange County, CA
    2000 Toyota Tacoma
    -3inch Fabtech Sprindle Lift Kit and Add-A-Leaf
    May I ask what coil overs they are
  10. Feb 10, 2018 at 5:42 PM
    Tour991
    James
    South Reno/Tahoe
    They are Downey springs and sleeves on bilsten 4600 shocks
  11. Mar 12, 2018 at 6:38 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Do you remember how long the ext length and collapsed length of the shocks were? I have doestch lift coils i will be installing soon but i need to know if the fabtech shocks i have now will work or should I order taller shocks
  12. Mar 13, 2018 at 2:28 AM
    BikerinBlak909
    SoCal
    96 LT 5 lug
    Fabtech n Doetsch kits are the same
  13. Mar 13, 2018 at 8:38 AM
    Tour991
    James
    South Reno/Tahoe
    not sure i sold the kit a few months ago
