Downhill brake saving
Discussion in 'Arizona' started by OH-MAN, Dec 20, 2010.
  1. Dec 20, 2010 at 7:30 PM
    OH-MAN
    OH-MAN [OP] Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Ran the 4 peaks trail for the second time sunday.
    I noticed on the first run I really used the brakes a ton on the downhill section close to the end on the way down from 4 peaks.
    Brakes were pretty smelly and I know brakes pretty good.
    This time I put the truck in 4low and let the engine brake help out .
    Now I did keep it under 25 mph so I don't think I hurt it that way.
    Is it bad to use it this way?
    I can only down shift to 3 on the 2 wheel drive and it is pretty much freewheeling and I have to ride the brakes a bunch.
    What can I do in an automatic other than 4 low?
  2. Dec 20, 2010 at 7:40 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    does yout truck have downhill assist?
  3. Dec 20, 2010 at 7:40 PM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Never had that problem. I've actually shifted right down to 1 on steep hills around here. Just in 2 wheel drive. If you get going to fast of course it will not shift down so shift before you speed up. You may have to apply the brakes to get it to shift lower.
    I drive like I have no brakes. I shift down always on steep hills before I'll use them. Never had a problem. I've also never had a problem with the brakes. My sig picture is me sitting on top of a mountain round here. That is basically the last of the trees.
  4. Dec 20, 2010 at 7:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should be able to go into "L" just fine. Try second or first next time. Regardless, running in 4low is fine too.
  5. Dec 21, 2010 at 4:57 PM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    I tried the downhill assist and it did not help slow down, I think it just helps you keep from locking up on a down hill . But shouldn't the abs do that?
    I must be doing something wrong in 2 wheel drive it seems I can only manually down shift to 3.
    I guess I will read the manual as that is allways the last resort!!!!!! :eek:
    Thanks all!!!
    This trail is on dirt and the two times I have done it the brakes were getting hot and I could definatly smell them.
    It drops pretty quick for the last 5 miles or so.
  6. Dec 21, 2010 at 5:01 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    My understanding is downhill assist only works in 4low. But yeah if you're off road, I'd throw it in 4low, shift to L and use downhill assist. That should keep you under 10mph.
  7. Dec 21, 2010 at 5:05 PM
    BritMike
    BritMike Well-Known Member
    NJ
    10 Black TRD OR
    Downhill assist - 4Lo, 2 or L below 15 mph. (Pretty sure it doesn't work if you've got the locker engaged)
    Remember though downhill assist will still use the brakes to slow you down if it has too.
  8. Dec 21, 2010 at 5:05 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Need a manual trans! :p
  9. Dec 21, 2010 at 5:08 PM
    jandrews
    '09 FourDubDee TRD OR
    I prefer to manually manage gears/brakes rather than use the DAC. But if it were a stupid long hill, I might let DAC do its thing.
  10. Dec 21, 2010 at 6:55 PM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    That is what I thought at the time but I soon came to my senses and realised I could find a better way to save my brakes than have an extra pedal to push a couple hundred times a day :D:D
  11. Dec 21, 2010 at 9:30 PM
    CaptMorgan
    CaptMorgan Well-Known Member
    Tempe
    Lift, tires, aux-in, LED Taillights, Flowmaster
    Under 10 mph would kill me! I was flying on the way down lol, love that trail
  12. Dec 22, 2010 at 4:42 AM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    I was trying to stay about 20-25 mph.
    I had to take it easyfor the two Jeeps following me :D
