Downhill braking causing engine to rev
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2017 Inferno SR5, Aug 14, 2018.
  1. Aug 14, 2018 at 8:49 AM
    2017 Inferno SR5
    2017 Inferno SR5 [OP] Member
    Todd
    2017 Inferno SR5 V6 Auto 4X4 DCab 6ftbed Tow Pack
    Has anyone else experienced this: Going downhill, a steep hill, but still on a State road, I touch the breaks to slow down and the engine revs from under 1,000 rpms to about 3,500 rpms. This is in an auto 6 cylinder, 3.5, 2017 Tacoma. She also seems slow to down shift when going up a hill, but I have mainly coincided that just the difference between a V8 manual (my old truck) and (this) a 6 auto. Thanks.
  2. Aug 14, 2018 at 8:51 AM
    Lunabird
    Lunabird Well-Known Member
    totally normal. its down shifting.
    BRFab, Skydvrr, jmneill and 5 others like this.
  3. Aug 14, 2018 at 8:53 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Its so you dont have to ride your brakes and overheat them. Its normal.
  4. Aug 14, 2018 at 8:55 AM
    2017 Inferno SR5
    Todd
    Okay Lunabird, I thought maybe so too, but it seemed such an extreme change in the rpms and was so loud I wanted to ask. Thanks.
  5. Aug 14, 2018 at 8:56 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    It's engine braking for you. Normal and preferred operation.
    Thunder Fist likes this.
  6. Aug 14, 2018 at 8:56 AM
    2017 Inferno SR5
    Todd
    Okay Mitch76, that makes sense. Thanks for responding.
  7. Aug 14, 2018 at 8:59 AM
    2017 Inferno SR5
    Todd
    Okay Doggman, thanks, I appreciate the feed back.
  8. Aug 14, 2018 at 9:00 AM
    DA3
    DA3 Well-Known Member
    USA
    I found this also happens on cruise control- most will coast down a hill not this TACO its jerky and revvy
  9. Aug 14, 2018 at 9:01 AM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    It’s actually fuel cut when this happens. It puts the truck into a certain rpm and completely shuts off fuel to get the best gas mileage. But mostly it just feels like engine braking which is also a good feature.
  10. Aug 14, 2018 at 9:01 AM
    2017 Inferno SR5
    Todd
    DA3, thanks good to know. I'll keep it in mind.
  11. Aug 14, 2018 at 9:06 AM
    2017 Inferno SR5
    Todd
    sancheeto likes this.
  12. Aug 14, 2018 at 9:07 AM
    Shipwreck
    Shipwreck Well-Known Member
    Johan
    Centennial CO
    2016 TRD Off Road Tacoma
    Stock
    Yup, totally normal... I do like that it does. Hate riding my brakes.
  13. Aug 14, 2018 at 9:09 AM
    2017 Inferno SR5
    Todd
    Shipwreck, I guess the dealership should mention it. It makes sense, but it is disconcerting at the time.
    Vmax540 likes this.
  14. Aug 14, 2018 at 9:16 AM
    Shipwreck
    Johan
    Centennial CO
    Stock
    Yeah I can see that being a worry if you dont know about it.
  15. Aug 14, 2018 at 10:50 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Yep. Totally normal. You should be driving it with the shifter for engine braking anyway.
    Save brakes. Doesn't hurt a thing.
    G.
    Rock Lobster likes this.
  16. Aug 14, 2018 at 11:45 AM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    actually brakes are cheaper to replace than a transmission that isn't built for transmission braking.
    edit: I should rephrase that to explain. normal day to day usage you should use your brakes as pads are cheaper to replace than constantly putting undue load on a transmission.
    Flash1034 likes this.
  17. Aug 15, 2018 at 10:24 AM
    Garyji
    Gary
    Sorry NoDak. Been putting "Undue Load" on my Tacos for 14+ years now with no complaints. Changed front pads on my 2nd gen at 100k and the brake guy said the rears still looked brand new. Tranny was fine too. I drive my Tacos in "MT Mode" as much as possible. It's way more efficient especially with the 3rd gen Engine/ trans combo.
    What ever makes you happy.
    G.
  18. Dec 23, 2018 at 3:18 AM
    Roy664
    Roy664 New Member
    Louis
    2017 black trd sport
    None yet
    My concerned is wen the road become slipry but realy slipry icy curved with hill ,then wen the engine brake keep on braking it become very hard to handle. I wish i can stop it.
  19. Dec 23, 2018 at 3:30 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    If it's slippery/icy, you shouldn't be driving so fast. Slow down and the system won't kick in.
    jmneill likes this.
  20. Dec 23, 2018 at 3:40 AM
    Roy664
    Roy664 New Member
    Louis
    None yet
    With an 18 weeler at your back on the north road slow down is not always the right solution. I just wish i can stop it to brake by itself.
