Downhill breaking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rellims, Dec 12, 2024.
  1. Dec 12, 2024 at 9:30 AM
    Rellims
    Rellims [OP] Well-Known Member
    Sean
    Denver, CO
    2021 Black Tacoma Trail
    Grill, headlights, tail lights, mirror turn signals, rock sliders, tint, bed cover, fog lights, KDMax tune, interior mods...
    Hey All,
    Is breaking on a steep decline at high speeds (65mph) with a loaded bed normal to shake badly? TIA
  2. Dec 12, 2024 at 9:31 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
  3. Dec 12, 2024 at 9:40 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Time to check your brakes.
    Probably worn pads, shoes, and possibly rotors too.
    Barsoom, Chew and Rellims[QUOTED][OP] like this.
  4. Dec 12, 2024 at 9:47 AM
    Rellims
    Sean
    Denver, CO
    Odd with only 32K on it.
  5. Dec 12, 2024 at 9:50 AM
    airforceb2cc
    Don
    KCMO
    Overheating the brakes has nothing to do with age or mileage. Most likely the brakes were overheated in the past and the heat cycle caused the rotors to slightly warp or there is excessive pad transfer on the rotors causing the pulsing feeling.
    soundman98, Barsoom and Chew like this.
  6. Dec 12, 2024 at 10:01 AM
    Rellims
    Sean
    Denver, CO
    Thanks for this info, I appreciate it.
  7. Dec 12, 2024 at 10:37 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Take it out of overdrive? -S- that helps when loaded.
  8. Dec 12, 2024 at 10:42 AM
    Rellims
    Sean
    Denver, CO
    Yeah, did that to downshift manually.
  9. Dec 12, 2024 at 10:43 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I had a braking vibration that started around 30K miles. I could feel the vibration when braking from about 50mph to 35mph. I don’t normally tow or carry heavy loads.
    Put PowerStop on two years ago and very happy with them.
    https://www.amazon.com/dp/B005FKS28C?ref=ppx_yo2ov_dt_b_fed_asin_title
    Rellims[QUOTED][OP] likes this.
  10. Dec 12, 2024 at 11:01 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Sounds like the rotors either need to be turned or replaced. The idea when on long declines is to downshift BEFORE you start down to a gear low enough to maintain a safe speed with minimal brake applications. Load doesn't really matter. Depending on the grade and what is a safe speed I use either 3rd or 2nd gear. If either my speed or rpm's get too fast just a little tap on the brakes will get things copesetic. I've driven 30+ miles down mountain passes before and only had to touch the brakes 10-12 times.
    That's how you prevent the rotors from getting warped. Constantly braking overheats and warps them.
    gudujarlson and Rellims[OP] like this.
  11. Dec 12, 2024 at 11:04 AM
    Rellims
    Sean
    Denver, CO
    It was 7% for 6-7 miles.
  12. Dec 12, 2024 at 12:49 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Don’t ride your brakes for anywhere near 6-7 miles. They could over heat, a fade, wear prematurely, and possibly become damaged. Use engine braking (s-mode if you have an auto).
    Rellims[OP] likes this.
  13. Dec 12, 2024 at 12:56 PM
    Rellims
    Sean
    Denver, CO
    Was probably 2 miles in before going to s mode.
  14. Dec 12, 2024 at 12:59 PM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    I've heard of people warping their brakes on hills like that in Colorado. The transmission will automatically downshift a gear or two if you're riding the brakes, but it's usually not enough. I'll put it in S4, S3, or even S2 depending on the speed to get a bit more engine braking. Even with the engine around 4000 RPM the engine braking seems pretty weak compared to other vehicles I've driven.
  15. Dec 12, 2024 at 1:29 PM
    gudujarlson
    Minnesota
    As much as warped rotors are reported on here, you’d think that Toyota might add a brake rotor temperature warning light. There’s a warning light and/or beeper for just about every other mistake a driver or passenger might make. Why not this one?
    Is it because brake rotors and pads are not covered under warranty?
  16. Dec 12, 2024 at 1:30 PM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    i've noticed this when going down vail pass on i70 in colorado. my truck was probably around 30k miles then too. been awhile since i went over that way. i recently swapped my pads at 60k and haven't noticed the same vibration, but havent done any higher speeds down any passes.
  17. Dec 12, 2024 at 1:39 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    what broke?
  18. Dec 12, 2024 at 1:46 PM
    M85
    Colorado
    2019 SR ACLB
    In my experience they don't actually warp, but they get uneven deposits of pad material. One time I had a single panic stop from around 45mph cause "warped rotors", and there's no way that created enough heat to get about normal operating temperature. In other words it's a little unpredictable when it happens.
    The transmission will downshift for you to dummy proof it. It doesn't downshift far enough in my opinion, but it's enough that you probably don't need to ride the brakes very hard on a 7% grade. Depends on the load though. Are you fully loaded but within the payload rating, over the payload rating, or towing a trailer?
    There could also be some tolerance in the grade warning signs. For example Eisenhower Tunnel to Frisco is I believe 6%, but it doesn't take much braking even without downshifts. I think Fremont Pass to I-70 says 7%, but in the steepest sections it feels like I need to burn off a lot of energy to maintain speed. Off the top of my head, that section of road is the hardest on brakes I can think of in Colorado because of the combination of slope and high speed limit.
  19. Dec 12, 2024 at 1:48 PM
    RIX TUX
    thats a steep one there
  20. Dec 12, 2024 at 1:48 PM
    gudujarlson
    Minnesota
    A 4600 pound (~2000 kg) truck traveling at 50 mph (~20 m/s) down a 7% slope will need to dissipate approximately 27 kW of heat by my napkin math.
    20 m/s x .07 = 1.4 m/s downwards.
    gravitational potential energy = mgh = 2000 kg * 9.8 m/s * 1.4 m =~ 27k joules
    power = energy/time = 27 kW
    Estimating the temperature a brake rotor will reach in 6-7 miles is left to the reader (or me if I get bored enough).
    EDIT: I looked up the heat capacity of steel to be 460 J/C and the typical brake rotor to be 7 kg. So making the approximation that the rotor does not dissipate any heat to its environment (terrible approximation) the rotor would get ~50 C hotter every second. 27 kW / 460 J/C.
    FunknNasty likes this.
