Downshifting to slow down?
Discussion in '1st Gen. Tacomas (1995-2004)' started by oofy15354, Mar 8, 2010.
  1. Mar 8, 2010 at 3:22 PM
    oofy15354
    oofy15354 [OP] Proud Tundra *****
    Dave
    Massachusetts
    Herculiner, Access Tonneau, Uniden cb, firestik antennae, Bosch Wipers, JVC Ipod headunit, Boston Acoustic Speakers
    I often throw on the over drive to shift down and slow the truck down instead of using the brakes up (especially with cops)
    is this bad on the transmission or anything? id rather replace brakes than a transmission.
    its an automatic btw
    Thanks guys
  2. Mar 8, 2010 at 3:25 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
  3. Mar 8, 2010 at 3:30 PM
    oofy15354
    Dave
    Massachusetts
    sweet deal. thanks
    anyone wanna call him a liar?
  4. Mar 8, 2010 at 3:31 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Nope....just make sure you're not downshifting too far.
    Like, if you're driving along at 50mph in DRIVE and downshift into 2nd - that might cause the rpm's to be way too high. Not a good idea to drop down that far.
  5. Mar 8, 2010 at 3:35 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Liar!
  6. Mar 8, 2010 at 3:39 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    "Throw on the overdrive" is not going to give any kind of engine braking!?! :confused: However, downshifting from overdrive, into fourth will.
  7. Mar 8, 2010 at 3:40 PM
    JDMcQ
    I think that he meant hit the overdrive button, which takes the transmission out of overdrive.
  8. Mar 8, 2010 at 3:42 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Its ok, called engine breaking or Compression breaking.
  9. Mar 8, 2010 at 3:46 PM
    carmellocafe
    KEVIN
    N. California
    Ok, so essentially you'd be downshifting from overdrive. Got it. Never seen the button. :eek:
  10. Mar 8, 2010 at 4:19 PM
    oofy15354
    Dave
    Massachusetts
    yeah sorry got that mixed up.
    idk where the button is on second gens but its on the shifter for automatic first gens, on the left side where you would put your thumb
  11. Mar 8, 2010 at 4:23 PM
    JDMcompliant
    JDMcompliant Professional Amateur
    Joe
    San Diego
    2010 Tacoma 4x4 4.0L V6
    I came into work this morning meaning to ask this question, but I never got around to it. Thanks for asking it :]
    I found myself engine braking in my '98 4Runner very often to give my brakes as much assistance as possible. Now that I'm actually moving the shifter as opposed to pressing an overdrive button, I feel like I could be causing some unknown problems :p
  12. Mar 8, 2010 at 4:24 PM
    ywen
    ywen Well-Known Member
    would downshift also be preferred on a slippery surface where if you braked, there would be high chance of slippage? Or use downshifting IN ADDITION to full ABS braking for those times when you need to stop faster than the normal brake distance allows?
  13. Mar 8, 2010 at 5:03 PM
    Beau02
    Beau02 Black Taco
    Beau
    Indianapolis, IN
    2002 4x4 Limited TRD V6 Auto (234k+, 1-owner)
    Lots of small stuff; Grillcraft MX, Bilstein 5100's, Deck Plate Mod w/ AFE air filter, Airaid MIT, braided SS brake lines, Redline Tuning QuickLIFT hood struts, Extang Full-Tilt tonneau cover, fog light mod, gray wire mod, power outlets on-demand, Diff breather ext, additional contours to passenger side from oak tree.
    If I recall correctly, my owner's manual actually refers to using the lower gears for braking - as in something to use them for.
    FWIW I've been doing just what you're describing in my truck for the past 140k miles. I use both the overdrive button and low-2 for engine braking and I haven't had a lick of trouble.
  14. Mar 8, 2010 at 5:13 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Downshifting is also great while towing. I come down from a lake that sits at the 7,500 foot level every weekend throughout the summer, and if I couldn't downshift I'd be worried about overheating the brakes. Going up the hill I throw her into 4th from overdrive once in a while when the automatic is hunting for a gear.
  15. Mar 8, 2010 at 5:19 PM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    ive noticed that if i toss it in neutral the truck will slow easier as well
  16. Mar 8, 2010 at 6:11 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    if he droped into 2nd and 50mph it would be ok.
  17. Mar 8, 2010 at 6:34 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    example: if you where going down a steep hill would you rather ride the brakes to the bottom or use a lower gear?
  18. Mar 8, 2010 at 6:44 PM
    Beau02
    Beau02 Black Taco
    Beau
    Indianapolis, IN
    X2 on the example above, and also, why does it make sense with a manual, but not with an auto? You're essentially doing the same thing, so one makes as much sense as the other, right?
    You're not going to wear out a transmission if you responsibly use it for 'braking' and maintain it properly. On the other hand, you will wear out brakes by using them as they are a wear item. So, if you can find reasonable ways of avoiding use of the brakes they'll last longer, and thus save money.
  19. Mar 8, 2010 at 6:51 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    this guy knows what hes talking about! :thumbsup:
  20. Mar 8, 2010 at 7:10 PM
    ywen
    Putting it in Neutral will not make it slow down faster. In fact, you are lossing any sort of engine braking. Put it into N if you want to coast longer.
