Downshifting while moving
Discussion in 'Performance and Tuning' started by bigpappa160, Dec 9, 2010.
  1. Dec 9, 2010 at 10:21 AM
    bigpappa160
    bigpappa160 [OP] Member
    Slocomb, Al
    16 Tacoma XP Rockstar Package
    I had this downshifting problem the other night. I was at a trafffic light light turned green gave it some gass got up around 20-25mph at the truck downshifted and then up shifted and it happen around 35mph also after I gave it some more gas it work fine. Then last night same thing happened downshifted around 20-25mph then upshifted but then the check engine light came on. Has anyone experienced this problem and if so what is the remedy? the truck is a 04 tacoma with 159k on it
  2. Dec 9, 2010 at 11:26 AM
    bigpappa160
    Slocomb, Al
    where do you get a code reader and how does that work
  3. Dec 9, 2010 at 11:43 AM
    STravis
    STravis Well-Known Member
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    Autozone can read the codes for you.
  4. Dec 9, 2010 at 12:12 PM
    bigpappa160
    Slocomb, Al
    thank You but how does the code reader work does it hookup to the engine
  5. Dec 9, 2010 at 1:08 PM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    plugs in to a plug in front of the accelerator pedal. Autozone will know what to do.
  6. Dec 9, 2010 at 1:09 PM
    matthew5olson
    matthew
    pittsburgh, PA
    but yes it does get its info from the ecu. takes a couple mins. nothing major. Its a diagnostic thing
  7. Dec 10, 2010 at 6:39 AM
    bigpappa160
    Slocomb, Al
    Thanks for the info, I'll get by there to day on the way home from work.
