Downshifting with no load
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Coppertone, May 11, 2021.
  1. May 11, 2021 at 2:56 PM
    Coppertone
    Coppertone [OP] Well-Known Member
    South Louisiana
    2021 Tacoma DCLB TRD OR
    My 2021 TRD OR has 1800 miles and it cannot hold the highest gear on flat ground with no load. On normal acceleration to 70, it will shift through all gears and into 6th (below 2000rpm), stay there for a few seconds and then downshift (or TC lockup?) and run above 2000rpm indefinitely.
    Other times will stay stead in 5th above 2000rpm, and then after 5 minutes or so, shift into 6th and the rpms will hover under 2000.
    Does anyone else share this issue? Since my truck is a 2021, I believe it has the latest transmission programming from the latest TSB.......assuming.
  2. May 12, 2021 at 7:37 PM
    Coppertone
    South Louisiana
    Anyone?
  3. May 12, 2021 at 7:48 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    At 70mph my truck stays in 6th until a grade.
  4. May 12, 2021 at 7:48 PM
    CocaineAndCreatine
    CocaineAndCreatine Strong in arm and weak in head
    Portland, Oregon
    2018 Beige DCSB OR
    SCS F5s
    Seems normal. Or it's still learning your driving style. Or get a tune.
  5. May 12, 2021 at 7:51 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    Did you change tire size already?
    Sometimes a good headwind will make it hunt between 5th and 6th.
  6. May 12, 2021 at 7:57 PM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    Tune it
  7. May 12, 2021 at 7:58 PM
    ethanolman
    ethanolman Active Member
    brand new 2021 SR5 shifts perfectly, so much different than the 2018 I had which was all over the place
  8. May 12, 2021 at 8:03 PM
    sid530
    sid530 New Member
    Chuy
    Tacoma SR5 2.7
    I’ve experienced the same issue. However in my case the cruise control
    is activated when this occurs. I’ve rented two Tacomas as well (one for cylinder and the other the V-6) and both exhibited the same tendency to gear hunt.
  9. May 12, 2021 at 8:05 PM
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    I’ve learned it to be normal on this engine and trans. I’ve been on flat ground and had wind cause it to downshift. Mine downshifts going up the other side of freeway underpasses. It is annoying and a reason people get tunes. I think the trans tune Toyota uses has some shortcomings.
    ive also notice it rushes to shift through the gears just on surface streets getting up to 45mph. Hear is what I mean, I will give it “X” throttle that allows me to leave the light at the same rate as everyone else. As it shifts through the gears all of a sudden it’s like I’ve lost power and now accelerating slower than others. It seems to short shift 4th to 5th and falls out of the power band.
    I’m only at 2600 miles but the more I drive the truck the more it annoys me. My 09 TRD Sport was more pleasurable to drive.
    Coppertone[OP] and tcjacado like this.
  10. May 12, 2021 at 8:14 PM
    Coppertone
    South Louisiana
    No, all stock.
  11. May 12, 2021 at 8:22 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    TC lock..
    Get OBDII app to see what's going on
