Downside of Leveling blocks?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jdeyler11, Feb 5, 2020.
  1. Feb 5, 2020 at 10:39 AM
    Jdeyler11
    Jdeyler11 [OP] Member
    2017 White TRD OR
    I understand that replacing springs, shocks, ect. will likely be a better option, but what are the downsides to just using blocks to achieve a leveled look?
    I have a 2017 TRD Offroad and as a broke college student I just don't want to pay for anything i don't have to since the truck already comes with the Bilstein shocks and what not... I intend to replace the bumpers and as far as trails I'm not looking for anything super hardcore, mostly just a lot of ranch driving and back roads to campsites so i dont feel like I need to replace the whole shebang.
    How bad would 1" in the back and up to level in the front be just using blocks/spacers compared to new springs and shocks?
  2. Feb 5, 2020 at 10:42 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Just save for a real lift. As you said you're a broke college student who doesn't need to spend money on things not needed. Blocks aren't needed.
    suaveflooder, Superdave1.0 and Tocamo like this.
  3. Feb 5, 2020 at 10:45 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    The Taco already sits higher in the back. Adding a 1" block in the rear will be worse!
    Superdave1.0 likes this.
  4. Feb 5, 2020 at 10:45 AM
    XUT
    XUT Well-Known Member
    Like what @GreyBaldTaco said, I would just wait for a real lift so you don't have to deal with undoing your blocks later. Do you have larger tires you're trying to put on or just go for a certain look?
  5. Feb 5, 2020 at 10:49 AM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    “Broke college student” [has $30,000 truck]
    czach, 44-16 Taco, NYCTaco52 and 9 others like this.
  6. Feb 5, 2020 at 10:50 AM
    GreyBaldTaco
    2019 F150 5.0
    It's pretty funny
  7. Feb 5, 2020 at 10:51 AM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    broke college students should not be driving a '17 TRD OR
  8. Feb 5, 2020 at 10:53 AM
    QuicksandTaco
    Cody
    Oregon
    Lol it’s your truck bro. Do whatever the f you want to it. You don’t need to justify and make up some bs to people on the internet.
    If you don’t want to spend the money on a lift, then buy a spacer kit and install it. There are probably 20+ threads covering literally any question you could have on any aspect of your Tacoma.
    suaveflooder and GreyBaldTaco like this.
  9. Feb 5, 2020 at 10:56 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I have some 1 or 1.5" blocks you can have them. They make the truck handle like shit. I replaced them with Dakar OME leafs.
    Junkhead, CrippledHo and GreyBaldTaco like this.
  10. Feb 5, 2020 at 11:14 AM
    Jdeyler11
    2017 White TRD OR
    No larger tires just wanting a little more clearance for if the need arrives/offset the weight of bumpers.
  11. Feb 5, 2020 at 11:17 AM
    Jdeyler11
    2017 White TRD OR
    Truck was a gift/split with what I could get for my old truck... I know the the idea of it is funny but the point is if I want to do anything to it I have to pay for it so Im just trying to figure out whats worth it and whats not.
    QuicksandTaco[QUOTED] likes this.
  12. Feb 5, 2020 at 11:18 AM
    XUT
    There's better solutions for that then!
    GreyBaldTaco likes this.
  13. Feb 5, 2020 at 11:20 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    There’s nothing wrong with spacers if you understand the limitations of spacers. Basically don’t drive the truck like you upgraded your suspension and you’ll be fine. The spacers place your stock shocks towards the end of their designed operating range. You run the risk of bottoming out or over extending them if you run them too hard and that could be catastrophic. But if you drive the truck the same way you’re doing now, you should be fine. Spacers are an aesthetic upgrade not a performance upgrade.
  14. Feb 5, 2020 at 11:26 AM
    GreyBaldTaco
    2019 F150 5.0
    Also, you need to upgrade your bumpstops so your shocks don't act as your bumpstops.
  15. Feb 5, 2020 at 11:33 AM
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    If all you want is an inch or two in the back, you can do a 3-leaf AAL in the back. That'll give you about 1.5" and you can match it with spacers in the front. And an AAL is like $100-$150 (last time I checked).
  16. Feb 5, 2020 at 11:34 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    Nothing wrong with it if you use them as intended...for looks. I have a spacer/block lift but went with new shocks in the rear. Handles and rides better than it did stock and I drive it hard but it's all street driving. It's my DD so I don't take it off road as I can't chance being without it for work.
  17. Feb 5, 2020 at 11:35 AM
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    Adding bumpers to a block lift sounds like a recipe for disaster. Think about if you're just trying to save money and something catastrophic happens because of that bad idea. You will end up spending way more money in the end. Even if there isn't a catastrophic error it will probably end up costing you in some way. Never step over a dollar to pick up a dime. Just do it right man, you never know when a proper suspension set up could save your life. Quick maneuvers etc. Dont you want your truck to preform safely when needed?
  18. Feb 5, 2020 at 11:45 AM
    Freegolf
    Denver
    Spacers/block negatively affect shock components, adding preload. So in FACT, concerning performance, that IS something wrong and definitely a negative, even if you're just driving in the "street". You're strut and spring are not performing at peak performance PERIOD. That is a "wrong" . Decreasing performance is what it is. Dont spread falsities.
  19. Feb 5, 2020 at 12:20 PM
    Superdave1.0
    SoCal
    No Sir Ree Bob. Adding rear spacers will not cause you to bottom out stock shocks. It does however cause the stock shocks to top out/overextend when drooping. That's why should add longer shocks. Just an FYI/service announcement from yours truly.
  20. Feb 5, 2020 at 12:56 PM
    Myles G
    Myles G Well-Known Member
    Myles
    level it, 1.25 inch wheel spacers, and 33s.
    cheap good looking build that wont destroy ride quality
    tires will be the most expensive part
    had this on my 2nd gen and looked flush
