Downsides to running sport springs with 5100's??
Discussion in 'Suspension' started by wmflyfisher, Nov 20, 2012.
  1. Nov 20, 2012 at 9:33 AM
    wmflyfisher
    wmflyfisher [OP] Well-Known Member
    Wes
    PCB, FL
    2010 Sport 4x4
    I'm about to purchase a set of 5100's and was wondering is there any downside to running a factory sport spring with the Bilsteins set to 2.5"?? No offroading what so ever.
    How would I benefit from running an OME 885 with the Bilsteins vs the factory spring? Lift should be the same right?
  2. Nov 20, 2012 at 9:53 AM
    david2011sr5
    david2011sr5 Well-Known Member
    take a guess
    MA/VT
    2011 SR5 4x4
    afe pro dry, weather tech floor liners,5100's on all four corners@ 0, eibach 620 coils. toytec 3/4" spacer driver/s & passenger/s, rear spring tsb w/toytec 1" blocks, 4runner sport wheels, in channel vent visors, 1.25 spidertrax wheel spacers on the front, Wet Okole's, smity tow hook.
    Seting 5100's on anything but the 0" setting puts pre-load on your coils. Pre-load=rougher ride. Puting a after market coil and setting 5100's @0
    Allows the coil to lift the truck=better ride/handling. With that said a lot of guys on here don't seem to mind the ride of the pre-loaded coils. the shocks in themself are a nice upgrade to the factory ones even with some pre-load. I had mine set @1.75" of lift and thought the ride was better than factory, but ended up putting aftermarket coils on for more lift and better handling.
  3. Nov 20, 2012 at 12:34 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    Just stiff. It'll jar you real good on those deep potholes but if you don't off road I wouldn't see any issues
