DownSouth Motorsports Shock Service
Discussion in 'Downsouth Motorsports' started by Downsouth Motorsports, Jan 23, 2014.
  1. Jan 23, 2014 at 11:22 AM
    Downsouth Motorsports [OP] Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    It has come to our attention, that there may be some confusion as to what we do here at #downsouthmotorsport. #wedoshocks we service everything 100% in house! Fox, King, ADS, Icon, Bilstein. Every shock we touch is cleaned, inspected, disassembled, parts replaced, shafts polished, reassembled, charged with nitrogen and then inspected again. All our service work is backed with a 1 year warranty on our work. #downsouthmotorsports #wedoshocks #offroadshockservice #offroadshockprep #shocks #shockparts #wedoitall #bzsx #doingshocksismorethanturningtubes #100percentinhouse #shocksonshocksonshocks #itswhatwedo #SHOCK #SERVICE
    Sorry for the HASH TAGS, I copied it directly from Instagram.
    But I want it to be clear, we service everything 100% in house.
  2. Jan 27, 2014 at 4:14 PM
    CVYota
    CVYota Damaged goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    But do you do shocks? :)
    I went to a local place and they didnt know the first thing about fitting a tacoma, they quoted me 4 weeks to build the shock and over a grand. I just called Micah and got the exact shock I needed within 5 min for a much better price IN STOCK!!, he knew the setup I had and what would work best. Can't beat that!
  3. Jan 27, 2014 at 4:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I heard they make a dam good cup of coffee too.
  4. Jan 27, 2014 at 4:19 PM
    Juan Solo
    Juan Solo Well-Known Member
    Johnny
    Houston
    2014 4x4
    How long should one go before thinking about getting shocks serviced?
  5. Jan 28, 2014 at 7:03 AM
    Lakeside, Ca. 92040
    parts headed your way today!
    That's a loaded question and there are many variables.. If they are leaking, if you have lost nitrogen, even if they don't leak but you have a lot of miles on them, its a good idea to open them up and go through everything and freshen them up.
    I recommend that you regularly check your nitrogen psi, clean the shocks and inspect them. You will be able to tell when they need to be serviced simply by doing the above.
  6. Jan 28, 2014 at 7:08 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    #wedocoffee #wedocoffeeandshocks #damngoodcoffee
    :D
  7. Jan 28, 2014 at 7:10 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Can you guys rebuild bilstein 5100 shocks?
  8. Jan 28, 2014 at 8:30 AM
    Lakeside, Ca. 92040
    The 5100 is a non serviceable shock.
  9. Jan 28, 2014 at 8:41 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    And they always send stickerz!!! :)
  10. Jan 28, 2014 at 8:43 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Remember the big "Leeper" coilover controversy:eek:? Well you guys rebuilt my leepers and they came back top notch. I got 35,000 on them now and still feel new. Big Plus with their service and getting them back to me in Hawaii under a weeK.
    Can you guys add the Icon CDC valve to the leepers?
  11. Jan 28, 2014 at 9:30 AM
    Lakeside, Ca. 92040
    I could contact Icon to see if it can be done if you like.
  12. Jan 28, 2014 at 2:30 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    If it can be done i'm definitely interested, but not until end of the year.
  13. Jan 28, 2014 at 2:51 PM
    Lakeside, Ca. 92040
    Let me know when you are getting closer and we can give them a shout!
  14. Jan 28, 2014 at 7:20 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Right on! Aloha.
  15. Jan 29, 2014 at 12:27 AM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    My front fox 2.5 reservoir shocks are leaking, took them out and replaced them with the stock ones I had as spares. What should I do?
  16. Jan 29, 2014 at 7:11 AM
    Lakeside, Ca. 92040
    Where are you located?
  17. Jan 29, 2014 at 9:46 AM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    I'm in El Centro, I was thinking on going San Diego Sunday
  18. Jan 29, 2014 at 9:56 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    How about old 2.0 SAW's? Lol
  19. Jan 29, 2014 at 10:11 AM
    Lakeside, Ca. 92040
    PM sent
    We can service them
  20. Jan 29, 2014 at 10:13 AM
    Large
    Large Red
    I had DSM rebuild my kings a year ago & couldn't have been happier with the service. Thanks & keep up the good work.
