Downstream 02 sensor wire matchup
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bluepine, Aug 10, 2020.
  1. Aug 10, 2020 at 12:30 PM
    Bluepine
    Bluepine [OP] New Member
    2012 reg cab tacoma
    Need help on matching my O2 downstream sensor wires to female harness. Sensor wires are 2 black , 1 blue and one white. Harness wires are 1 blue, 1 white with a seperate internal ground, 1 brown andb1 green. Also if I'm splicing what do I do with bare internal ground by white wire in harness
  2. Aug 10, 2020 at 1:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Sounds like you have the newer sensor and your truck uses the older wiring harness.
    Older pre-2012
    Newer 2013+
    I going to take a guess and say the black wires are ground.
    But let’s let @Muddinfun and @Jimmyh take a look.
  3. Aug 10, 2020 at 5:41 PM
    Muddinfun
    Muddinfun Well-Known Member
    This is the message that the OP posted to my profile. This sheds a little more light on the subject, but the only thing I know is that the bare wire is a grounded shield to protect the signal from electrical interference. That's all I've got.
    "Hey my 2012 reg cab 4cyl Tacoma downstream 02 sensor and female harness that the 02 plugs into got chewed by dogs. I have 2 blacks wires in O2 sensor and 1 white and 1 blue, on my harness I have 1 brown, 1 blue, 1 green and a white with a bare stranded wire by it but separated by insulation do you know how wires wire together and what do I do with stranded wire which I'm assuming is a ground of some sort"
    Jimmyh and TnShooter like this.
  4. Aug 11, 2020 at 1:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes the Bare Sheath is a Electronic Noise Shield as stated above and indicated by the dotted line around the White Signal Wire OX1B and should connect to the brown Ground wire.
    It also seems that the black wire is a ground on the 2013 + years into the ECU and if connected to your 2012 harness will go to the brown Ground wire E2 and should work just fine.
    White wire OX1B = Signal Wire to ECU.
    Green Wire HT1B = Heater Signal to Heated O2 Sensor.
    Black Wire ( EX1B on 2013+ Brown Ground E2 on 2012 ) = Ground wire for O2 Sensor Heater.
    Blue Wire +B = + Power to the sensor.
    Brown Wire = Shield Ground Wire.
    Stranded uninsulated sheath = Electronic Noise Shield.
    I hope this helps somewhat.
    TnShooter likes this.
  5. Jul 31, 2021 at 3:06 PM
    Rola2010
    Rola2010 Well-Known Member
    Honolulu, HI
    2010 Tacoma 2wd base RC
    A bit of an old thread but if anyone can help - I have a P0137 code and am chasing it down. I posted about it here but just want to confirm what to do with the unshielded bit of wire? It was just covered with electrical tape, is that how it should be?
  6. Aug 1, 2021 at 7:01 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You need not do anything with that bit of shielding wire. That end is not connected and should not be connected. The other end is or should be connected to chassis ground. If you want to verify that it is connected to ground check it to ground with a DMM meter.
  7. Aug 1, 2021 at 7:24 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    leave as is as jimmy has implied. Connecting at both ends can cause circulating currents and noise in the system.
    Jimmyh and Rola2010[QUOTED] like this.
  8. Aug 2, 2021 at 12:19 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Commonly called a ground loop and is an undesired condition which could cause all kinds of crazy symptoms.
    6 gearT444E[QUOTED] likes this.
