Drafty Cab
Discussion in '1st Gen. Tacomas (1995-2004)' started by TACO in SC, Dec 28, 2014.
  1. Dec 28, 2014 at 7:43 AM
    TACO in SC
    TACO in SC [OP] TuRD
    Andrew
    Greenwood, SC
    '03 Tacoma Ex Cab 4x4 V6 5-Speed
    Pretty well stock
    My wife has been complaining about feeling a cold draft on her feet during these colder months. She says it seems to originate from the upper RH side under the dash of the passenger side. I've looked up there but don't see any obvious source.
    Have any of you experienced this? Where should I look to track this down? I've told her to wear thicker socks but that wasn't the answer she was looking for. :rolleyes:
    <-- It concerns this truck.
    Thank you,
    Andrew
  2. Dec 28, 2014 at 8:30 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    A woman with cold feet?
    Black97v6MT and tims007 like this.
  3. Dec 28, 2014 at 8:37 AM
    TACO in SC
    Andrew
    Greenwood, SC
    Pretty well stock
    Yea, that is quite unusual isn't it.
    tims007 likes this.
  4. Dec 28, 2014 at 8:43 AM
    Shelf Life
    Rob
    Central Oregon
    He hee. I dunno, the area your talking about may be behind the glovebox where air comes through your cabin air filter.
    tims007 likes this.
  5. Dec 28, 2014 at 9:56 AM
    TACO in SC
    Andrew
    Greenwood, SC
    Pretty well stock
    I don't believe my '03 Tacoma has an air filter. But I guess I could pull the glove box and look around.
  6. Dec 28, 2014 at 9:56 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    sounds like air is getting into the ductwork and blowing through the dash fan that is right where she feels the air.
    check the door to the fresh air intake vent is closing all the way, I think that is going to be the problem.
    set the climate controls to the recirculate air position and it should close that door if it is working correctly and sealing properly
  7. Dec 28, 2014 at 10:24 AM
    TACO in SC
    Andrew
    Greenwood, SC
    Pretty well stock
    I'll check that out. She feels it when the air is on the recirculate air position more so than when it is open. I figured when it is open it us creating positive pressure in the cab that has to blow out that same hole, wherever it is.
    Today I am getting ideas, will tackle it tomorrow.
  8. Dec 28, 2014 at 10:58 AM
    Shelf Life
    Rob
    Central Oregon
    Looks like your right there. I guess they didn't have them until 2006.
  9. Dec 28, 2014 at 2:27 PM
    keakar
    karl
    louisiana
    could be sucking in air from the kick panels so try pulling them and taping plastic over then to seal out any air leaks, also check if its coming from behind the door panel, if so pull that and tape plastic over it to seal the air out.
    might be best to pull the passenger seat out and lay on the floor while the wife drives on fast road so you can feel and locate exactly where its coming from because that may be the only way to locate and fix this quickly or you might spend a lot of time guessing where it might be coming from.
  10. Jan 2, 2015 at 8:21 AM
    TACO in SC
    Andrew
    Greenwood, SC
    Pretty well stock
    Well I pulled the glove box out but could not find any obvious route for air to be entering. Not wanting to spend a whole lot of time and effort I reassembled the glove box and stuffed the area with some batting material that I had.
    I am hoping this will block the air from blowing directly on her feet, even though it will still be entering the cabin. She has not yet ridden with me but we should be able to test my "repair" this weekend. I'll report back the results after testing.
    Thanks everyone for your help.
  11. Jan 2, 2015 at 9:43 AM
    markmb45
    markmb45 Well-Known Member
    Mark
    Utah
    99 4x4 Reg Cab 3.4, auto, e-locker
    V6,Auto, e-locker 4runner dash, seats
    On the early Tacomas 95-00 with the cable controls. The air mix damper cable would break allowing cold air in on your feet. This cable tied in on the warm-cool control. Not sure if the 01-04 Tacomas use cables. But the controls might be simular.
  12. Oct 27, 2015 at 1:56 PM
    TACO in SC
    Andrew
    Greenwood, SC
    Pretty well stock
    Well she again has cold feet. I guess I need to figure out some way to break into the box where the valves are to see if one isn't sealing. None of the other attempts have yet solved the problem.
  13. Oct 27, 2015 at 3:19 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Have someone drive the truck with you in the passenger seat. While going down the road, feel up under the dash looking for the air leak. Feel around the door seal.
  14. Oct 27, 2015 at 3:22 PM
    DrFunker
    DrFunker Well-Known Member
    My wife's civic had the same issue. Never got to the bottom of the issue as it wasn't my car to poke around in and she never seemed to give two shits.
  15. Oct 27, 2015 at 10:36 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    check all the grommets where harnesses come through the fire wall
  16. Oct 28, 2015 at 5:27 AM
    TACO in SC
    Andrew
    Greenwood, SC
    Pretty well stock
    Perhaps I should do this after removing the glove box. I've checked the grommets and they all look tight.
  17. Oct 28, 2015 at 8:54 AM
    LocknLoad
    LocknLoad Well-Known Member
    near the Cherohala Skyway, TN
    2015 DC Off-Road 4x4
    or ... you could just give her a blanket ....:thumbsup:
  18. Oct 28, 2015 at 9:21 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
  19. Oct 28, 2015 at 9:34 AM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    let her drive instead :p
  20. Oct 28, 2015 at 1:43 PM
    TACO in SC
    Andrew
    Greenwood, SC
    Pretty well stock
    Not going to happen! But maybe the snuggie. ;-)
