Drain Bolt coming loose
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RX2RIDE, May 14, 2010.
  1. May 14, 2010 at 7:25 AM
    RX2RIDE
    RX2RIDE [OP] Well-Known Member
    Everett, WA
    09 TRD Tacoma (mine), 08 Sport 4 Runner(Wife)
    I have a ongoing issue with the engine oil drain bolt becoming almost just finger tight when I service my 09 Tacoma and my 08 4 Runner. Same engine (4.0). I am thnking it must be the be the gasket that I am getting from the dealer. It looks almost like a cardboard (for lack of better terms) gasket. Any suggestions? I am now in the habbit of checking it every 1500 miles or so and just giving it a little snung turn of the wrench.
  2. May 14, 2010 at 7:38 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    Get some new gaskets? And make sure the bolt isn't stripped.
  3. May 14, 2010 at 7:45 AM
    gonzo6up
    gonzo6up Well-Known Member
    Middle Tn
    09 tacoma SR5 4x4 sport
    tint/ vent visors/ seatbelt chime mod/ DTRL Mod
    i dont use the gasket on mine and just 1/4" turn past finger tight works good for me, sounds like some of the threads could be stripped towards the bolt head
  4. May 14, 2010 at 7:49 AM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    If the threads are stripped on the bolt, replace it. If they're stripped in the pan, carefully wrap the bolt threads in teflon tape. You don't want to wrap the first couple threads, so there's no chance of some tape shredding off and getting into the oil. If it's just a case of the damn thing won't stay tight, use some Loctite removable. Ask the guy at the parts counter which one.
    winkel likes this.
  5. May 14, 2010 at 8:12 AM
    1980 Well-Known Member
    The Dust Bowl
    There are several sources for oversize self-tapping replacement drain plugs online. However, if you have troubles tightening the plug with a washer you might look and see if there are actually two washers there -- the original metal one might be stuck to the bottom of your drain pan.
  6. May 14, 2010 at 8:12 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Sounds more like the bolt hole threads are stripped, if that's the case you can take off the oil pan and carry it to a machine shop. Let them re-thread it bigger to the next bolt size, you would need a new bolt too but that's the best fix IMO. Nothing wrong with the fiber (cardboard) OEM gaskets, a lot of auto manufacturers use them.
  7. May 14, 2010 at 9:27 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    After you're done making sure the threads are ok, put in a fumoto oil drain valve and you'll never have a problem again. I've used them for years and they're great.
  8. May 14, 2010 at 10:21 AM
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    Check the torque on the bolt
  9. May 14, 2010 at 3:26 PM
    ASE_MasterTech
    ASE_MasterTech Well-Known Member
    Monmouth County, NJ
    2010 TRD Sport DBL\Cab
    Wet Okole seat covers, Westin Platinum Oval tube steps, Rear spring TSB plus Super Springs, D-Rings in all bed bolts, Tailgate reinforcement mod (for loading Harley)
  10. May 15, 2010 at 2:31 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Would my skid plate still cover/protect
    this valve on the rocks/trail?
  11. May 15, 2010 at 6:40 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    They say if you use it offroad to buy a clamp:
    For users under extreme conditions:
    If you are using the Engine Oil Drain Valve on off-road vehicles such as farm tractors and logging equipment under extreme environment (i.e. corn fields, brush areas), it is recommended that a hose clip as shown below be used for extra safety and security. The hose clip, which can be purchased at any hardware stores, will firmly keep the lever in the locked position at all times.
    Drain Valve Size Hose Clip Size T, FG Series 11/16" Clip F Series 5/8" Clip
    I am going to pick two of these up from my local dealer. At 20 a piece, making the oil change that less nasty. I am all for it.
  12. May 15, 2010 at 6:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Maybe. I have seen a few get knocked off.
  13. May 15, 2010 at 8:33 AM
    dirthawker1313
    dirthawker1313 Well-Known Member
    maybe or DEFINITELY
  14. May 15, 2010 at 9:05 AM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    Threadlocker 707 FTW
  15. May 15, 2010 at 10:27 AM
    lazaro
    lazaro Well-Known Member
    Garry
    Chesterfield, Virginia
    2010 DC BSP 4X4 TRD Off-road
    Stainless Nfab Steps painted black, Acces Tonneau cover, LED dome and map lights, Weathertech floor mats, EGR slimline visors, Wicked Flow 13 mufflers, ultragauge and 4X4 illuminated switch mod, receiver shackle from Timichi and Redline QL plus hood struts.
    On my last oil change (my very first) drain bolt came out with no washer. I was thinking maybe it fell in the oil pan drain. Anyway I had one that came from the OEM filter I bought. As I was tightening the drain bolt, I noticed that it was not as flush as it was before. :eek:
    Then I read from other posts that the original washer might be stuck in the pan. I just tightened it real snug but I doubt if its torqued at 30 ft lbs. Might be around 20 ft lbs. I do not want to risk stripping it. Anyway, I inspect it occassionally and no leaks and no sign of it coming out.
    On my next oil change I will consider the fumoto and make sure that the old washers are definitely out. I am keeping an eye on it.
  16. May 15, 2010 at 11:57 AM
    dee_bo
    dee_bo Well-Known Member
    DFW
    2007 TRD Sport Tacoma
    None yet
    I had this problem too last oil change...don't think any threads are stripped...might be cause of the plastic washer I replaced the original with....might need a better washer?
  17. May 15, 2010 at 3:19 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    From the dealer tech..Drain plug:18 lb.ft.
  18. May 15, 2010 at 3:25 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    Thanks for the info.
    Did they have skid plates?:confused:
  19. May 15, 2010 at 3:30 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    depends on the skid plate. just installed one on mine last oil change and it sticks about 3/4" below the oil pan. as long as that is still covered by a GOOD skid, then you're ok. i've got a couple inches between my ATO skid and the bottom of that drain valve. nothing should touch it in this case
  20. May 15, 2010 at 4:16 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    That's good to know.Thanks!! :thumbsup:
    I have BudBuilt.
