Drain holes in the bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by greyhound, Jul 2, 2011.
  1. Jul 2, 2011 at 3:05 AM
    greyhound
    greyhound [OP] Member
    Mass.
    2011 V6 4X4 SR5
    Are the holes at each corner at the front of the bed intended as water drains only or are the for extra "D" ring tie-downs? Any harm using these holes for extra "D" rings?
  2. Jul 2, 2011 at 3:13 AM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    the three holes in the front of the bed are used as drainage. only harm in using them for tie down d rings is lack of drainage but those old plastic bed liners you could buy never had drainage either so i dont see any harm being done.
  3. Jul 2, 2011 at 3:17 AM
    808TRDTaco10
    808TRDTaco10 Black Sand Mirror
    Justin
    Big Island, Hawaii
    10 Access Cab TRD OR 5AT 4x4; 08 Regular Cab 5MT 4x4
    TRD Off Road 265/75/16 Goodyear Wrangler Duratrac Load Range C | Toytec Ultimate Lift with Emu Dakar Leaf Packs | 3* Axle Shims, CB Drop, Sway Bar Relocates | AVS Vent Visors, AVS Bugshield | Scangauge II | Wet Okole Seat Covers | Weather Tech Floor Liners | Pop n Lock | OEM Bed Mat | Truxedo Lo Pro QT Tonneau Cover | TRD Cat Back Exhaust | Aftermarket Alarm System | Pro Coat "Electronic Rustproofing"
    I personally wouldn't plug up those drainage holes, but then again we do have non-metal beds anyway so it can't really do much harm, if any.
  4. Jul 2, 2011 at 3:25 AM
    greyhound
    Mass.
    2011 V6 4X4 SR5
    Did a search on this subject after my original post (not unusual for me to approach things a$$-backward...) Mavrick491 had a nice write-up and I think I'll use his way of drilling new holes near the factory drains.
  5. Jul 2, 2011 at 3:42 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Pro grille, remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    Most people, including me, use the factory bolts that are already there at the front of the bed. Not sure if I'm missing something, but why not use those?
  6. Jul 2, 2011 at 4:55 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    I for one enlarged the exsisting drain holes.
  7. Jul 2, 2011 at 7:33 AM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    +1 No joke... after a good 15 minutes of rain the bed is starting to look like a pool that is half full.
  8. Jul 2, 2011 at 7:57 AM
    DanCorcoran
    DanCorcoran Active Member
    Dan
    Richmond, VA
    2011 4x4 Auto Regular Cab
    I believe D-rings anchored in the plastic of the bed would be very likely to rip out if you put any stress on them. As other threads have described, it's quite easy to remove the bolts holding the bed to the frame and anchor a D-ring there...much stronger.
  9. Jan 24, 2012 at 10:15 AM
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Greg
    Illinois
    05 Prerunner SR5 TRD off road
    If I may inquire, how big did you enlarge them too. I am thinking I am going to do that too.
  10. Jan 24, 2012 at 10:19 AM
    CVYota
    CVYota Damaged Goods
    Andy
    Crescenta Valley
    '11 4X4 DCLB SR5 2.5 gen
    Same here, the slightest amount of dirt blocks them up.
    The D rings come with a piece of metal for the underside of the bed. but if you are hauling something that can rip it out, you can alwys put a larger bracket underneath.
  11. Jan 24, 2012 at 10:47 AM
    jpmorrisvb
    Jimmy
    Virginia Beach
    About 3/8" - 1/2" .... a some time back ... slow and easy with the drill .... works like a champ.
  12. Jul 15, 2013 at 1:58 PM
    Markcape
    Markcape Old as Dirt
    Mark
    Cape Cod,Ma.
    11 Tacoma A/C Debadged
    Ionic S/S 4in. Oval Running boards Sound Shocker/Stereo radio Aux. input mod. "new" Blower motor Installed/TSB WeatherTech mats Pro Cargo net in bed Console net Tailgate anti-theft mod. ImMrYo Mirror Lift bracket u RainX Wiper Blades
    I enlarged my drain holes. Used Dewalt cordless with my metal drill bits. Use slow speed. I started with existing size and stepped up by two sizes each bit until I reached 1/2 Size. BIG difference drainage. Even debris flows out. Go slow! drilling. I used #1 drive hand speed. Good luck.
    Mark/ Cape Cod :)
  13. Jul 15, 2013 at 2:08 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    Its 'plastic' go whole hog
