Drained 7.5L out of my engine oil pan. Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rob01, Dec 9, 2014.
  1. Dec 9, 2014 at 5:06 PM
    rob01
    rob01 [OP] Active Member
    Winnipeg, Canada
    2010 silver Crew cab TDR sport
    This is getting weird can anyone solve this. Here is what happened. Truck is a 2010 4.0 Trd
    1)In 2012, truck has 20,000 miles on changed oil and drained 8 litres of oil out. So kept an eye on the oil level.
    2)Did oil changes every 5-6000 miles and always measured around 5litres when i drained, everything good until 66,000 miles
    3)did oil change this week truck has 66,000 miles and took out 7.5litres of oil out of engine.
    All fluids r okay the only thing left i can think of is gas is getting in the oil, oil looks diluted. Also I always put in 5.2Litres when filling up and never add any oil between changes.
  2. Dec 9, 2014 at 5:10 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    I cannot tell you why the difference, but If you had 2 to 3 litres of gas in the oil, which is over a half to over three quarters a gallon, the truck engine would most likely be toast. You might want to have the oil analyzed. Also 2 to 3 extra litres in the crank case would most likely cause some serious smoking or internal engine problems from piston slap.
  3. Dec 9, 2014 at 5:31 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I think you mean quarts?
  4. Dec 9, 2014 at 5:33 PM
    adamr94
    adamr94 Well-Known Member
    Adam
    NC
    06 Regular Cab 4x4
    That's extremely strange to drain that much oil.
  5. Dec 9, 2014 at 5:37 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Litres in Canada
  6. Dec 9, 2014 at 5:39 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  7. Dec 9, 2014 at 5:40 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    u flushed the tranny by accident oop
  8. Dec 9, 2014 at 5:42 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    If you drained into a clean pan and kept the used oil clean, I'd be sending in a sample of it for analysis. Do you ever add coolant? If not, I suspect you are correct, you have a case of fuel dilution on your hands. Is there a common denominator, like extreme cold, extended idling...? Have you lent your truck out where some dipstick that couldn't read the dipstick overfilled it?
    And maybe most importantly for your wallet, was the issue documented with your dealer while still under warranty?
  9. Dec 9, 2014 at 5:44 PM
    savedone
    Gerald
    Texas
    I don't think the truck would move with no oil in the tranny. :D
  10. Dec 9, 2014 at 6:03 PM
    rob01
    Winnipeg, Canada
    First of all a quart and a litre r almost the same. When this happened both times it happend in colder weather, Sinced it happened the first time I have constantly checked the level and even measured it when i did oil changes and everything has been ok until now. The only thing that i noticed is when i start it up in the morning in cold weather it idles up and down and even stopped on me once.
    Could it be the airflow sensor causing the truck to run lean.
  11. Dec 9, 2014 at 6:17 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is the truck in the same spot each time you change the oil?
    Do you use a jack to jack the truck up?
    Is the truck on an incline when you are changing the oil?
    I park on a flat and level spot when changing my oil.
    I don't use a jack, I crawl under and drain the oil.
    I then remove the old oil filter and replace with the new oil filter.
    I then fill the oil up to the upper mark on the oil check stick.
    Then start the truck and let it run for about 10 secs. This fills the new oil filter. Finally I add more oil to the engine to bring the oil level back to the upper mark on the oil check stick.
  12. Dec 9, 2014 at 8:25 PM
    SxSW
    SxSW Well-Known Member
    Joe
    NM
    14 Base
    Might be a slight head gasket leak letting water into the oil.
  13. Dec 9, 2014 at 8:28 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    This x50
  14. Dec 9, 2014 at 8:47 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Excessively rich if anything, or a dribbling injector. How cold ambient temps are we talking?
  15. Dec 9, 2014 at 8:48 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    How could transmission fluid get into the crankcase? Didn't think so.
  16. Dec 9, 2014 at 9:20 PM
    rob01
    Winnipeg, Canada
    All fluids have been checked and r good. When I look at the oil their is no distinct smell of gas probably because its absorbed in the oil. I could tell I had a problem right when I let the oil plug out, instead of falling nice in the pan it splashed all over and out of the pan just like my 1st time it happened. Weird thing is truck still runs good, no noticeable increase in mileage. Also with my business I do alot of oil changes on heavy machines and only time a engine increased in oil was when a hydraulic auxillary pump leaked hydraulic oil into the engine from a bad seal.
  17. Dec 9, 2014 at 9:49 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Gotcha - I'm aware of the Krazieness :p out there, I thought you meant that transmission fluid was mixing with the engine oil. :cool:
  18. Dec 9, 2014 at 10:08 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Does it light on fire lol
  19. Dec 9, 2014 at 10:16 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Subbing cuz curious
  20. Dec 9, 2014 at 10:28 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    He's in Winterpeg, so water from the red river flooding is more likely.;)
