Drained my transmission fluid by accident - what now?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ComaTSS, Jul 18, 2015.
  1. Jul 18, 2015 at 5:29 PM
    ComaTSS
    ComaTSS [OP] Member
    Evan
    Arkansas
    '13 PreRunner TSS Edition V6 SR5
    I know, I know, I am an idiot. I was changing my oil (my 4th time to change the oil on this truck) and I slid under the truck saw the plug for the transmission fluid pan unscrewed it, saw that it looked reddish when coming out, thought hm thats weird and let approximately 3-4 quarts drain out of the transmission. Now what to do?
    Option A - Drive to dealer about 5 miles away (Probably not a good idea since I am 4 quarts low on transmission fluid)
    Option B - Go buy some Toyota ATF substitute fluid from Wal-Mart and put 3-4 quarts of that in there with the rest of the fluid and perform the temp test with the overflow to make sure I have enough and don't worry about it anymore
    Option C - Put 3 quarts of substitute fluid from Wal-Mart in and drive to dealer, tell them what happened and replace all fluid
    Option D- Call dealer and tell him what happened and get it towed to dealer
  2. Jul 18, 2015 at 5:33 PM
    Longboard1110
    Longboard1110 ...................
    San Jose
    A few things
    1) drain the rest of the fluid
    2) never go to Walmart
    3) purchase proper amount of transmission fluid at reputable auto parts store
    4) refill transmission
  3. Jul 18, 2015 at 5:36 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    DO NOT DRIVE IT.
    You drained the ENTIRE PAN out. (The system holds ~11-13 quarts total.... but its still NOT OK to drive with 3 quarts down)
    Get in another car go to the dealer and grab 4 quarts of the toyota WS fluid and fill the thing with 3 quarts. You will then have to properly go through the top off procedure.
  4. Jul 18, 2015 at 5:36 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Sealed transmission. Have to pump new fluid in through trans lines by radiator.
  5. Jul 18, 2015 at 5:38 PM
    willie64
    willie64 Willie64
    willie64
    BEND OR
    (slowly becoming less than) Stock '03 3.4L 4x4 TRD SR5
    144 watt led lights on front 36 watts x2 led on the back, cb, Kenwood ham, icon 3" lift, 285/75/16 Fierce Attitude tires, JoeZilla sliders, 4x innovation rear bumper, ARB front bumper. Snorkel. On the workbench: more stuff I can't afford.
    Take the other car to auto parts store, get correct fluid and refill.
    Stay away from Wally world, the evil empire.
  6. Jul 18, 2015 at 5:38 PM
    nd4spdbh
    SoCal
  7. Jul 18, 2015 at 5:39 PM
    DrFunker
    DrFunker Well-Known Member
    This happens much more than I would have expected.
    Why is that?
  8. Jul 18, 2015 at 5:39 PM
    ComaTSS
    ComaTSS [OP] Member
    Evan
    Arkansas
    Only the Toyota Transmission Fluid like it recommends or is a different type ok if it says it complies with Toyota ATF standards?
  9. Jul 18, 2015 at 5:42 PM
    nd4spdbh
    SoCal
    if you cant get the actual toyota WS fluid one that "meets the specs of toyota ws" will be fine
  10. Jul 18, 2015 at 5:44 PM
    ComaTSS
    ComaTSS [OP] Member
    Evan
    Arkansas
    Even if it's only 3 quarts of the new fluid and the rest is still the original fluid?
  11. Jul 18, 2015 at 5:46 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    dakotasyota likes this.
  12. Jul 18, 2015 at 5:48 PM
    Gearheadesw
    Davenport Fl
  13. Jul 18, 2015 at 5:54 PM
    ComaTSS
    ComaTSS [OP] Member
    Evan
    Arkansas
    Except through what?
  14. Jul 18, 2015 at 5:56 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There is supposed to be a transmission fluid that i much better than Toyota WS fluid, I do not know who makes it or what type it is though, it is circulating around here somewhere and I'm sure someone will chime in on which one is better. The rest of the posters have provided you aojnd advice, especially the poster talking about the fill plug. Good luck to you OP. It happens, if you learned from your mistake then you are good to go.
  15. Jul 18, 2015 at 5:58 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    I used Valvoline Maxlife from *gasp* walmart.
    I don't know about mixing them though, I did a complete flush through the cooler lines.
  16. Jul 18, 2015 at 5:58 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    If you are doing a full flush, any name-brand fluid that complies with Toyota WS spec (e.g. Valveline MaxLife) is good. If you are topping up (where new fluid mixes with existing Toyota fluid in the trans), using Toyota-branded fluid is recommended.
  17. Jul 18, 2015 at 6:00 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Fill it back up :notsure:
  18. Jul 18, 2015 at 6:00 PM
    Gearheadesw
    Davenport Fl
    Phone didn't like that answer.
    On my '12 Sport I had to use the drain and fill process outlined by mountainlion, I think was the OP. Have to disconnect the trannny lines by the radiator to fill. have to pump out the old with the pump in the trans itself, then pump in the same amount by hand through large access bolt hole on side of tranny. I think you can just pump in the same mount of fluid you let out by accident.
  19. Jul 18, 2015 at 6:05 PM
    ComaTSS
    ComaTSS [OP] Member
    Evan
    Arkansas
    See my problem is the dealership won't be open until Monday, and I'm guessing that's the only place I can get the Toyota fluid?
  20. Jul 18, 2015 at 6:07 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    That will be way to much fluid cold.
    Don't do this.
    You have to check the level at the right temp with the engine running.
