Drained Radiator Coolant, Filled Reservoir But I Know More Needs to Go In
Discussion in '2nd Gen. Tacomas (2005-2015)' started by awoit, Sep 15, 2021.
  1. Sep 15, 2021 at 7:14 PM
    awoit
    awoit [OP] Well-Known Member
    CA
    08 TRD, SR5
    Edit: Lots of detail in several other threads helped me determine what I did after messing up the first time..
    After research I drained radiator, and block via drain valves (1 on each side of block) and then refilled through radiator cap (2.5-3 gallons).
    Cheers
  2. Sep 15, 2021 at 7:18 PM
    Bishop84
    Bishop84 Well-Known Member
    Fill the rad through the rad cap. Stop driving the truck.
    Skrunner, Wattapunk, b_r_o and 2 others like this.
  3. Sep 15, 2021 at 7:19 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Did you fill the radiator or the overflow tank?
    davidstacoma likes this.
  4. Sep 15, 2021 at 7:30 PM
    awoit
    CA
    08 TRD, SR5
    That’s the one with the warning on the top? Do I need to siphon a bit out of the visible reservoir so I don’t overfill it?
  5. Sep 15, 2021 at 7:33 PM
    Bishop84
    Yes remove that and funnel in coolant, you likely caused an air lock, so it needs to idle with the cap off and fluid full.
    Leave the reservoir alone until the system is properly filled.
    https://www.youtube.com/watch?v=THcMQbOSuZo
    Dm93 likes this.
  6. Sep 15, 2021 at 7:34 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The reservoir is only there to allow for coolant expansion during normal engine operation, the system must be filled through the radiator cap.
    The reservoir should be kept between the min and max marks after the system is filled and the engine is cold.
    Total fill is around 2 gallons, if you just drained the radiator and the reservoir and not the block it will probably only take about a gallon.
    davidstacoma and DGXR like this.
  7. Sep 15, 2021 at 7:44 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    OMG.
    Gr8rSherman8r, Knute, b_r_o and 4 others like this.
  8. Sep 15, 2021 at 7:46 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    That's how you do it on vehicles where the radiators aren't the highest point in the system.
  9. Sep 15, 2021 at 7:54 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    pahaf, Gr8rSherman8r, Sig45 and 5 others like this.
  10. Sep 15, 2021 at 8:28 PM
    awoit
    CA
    08 TRD, SR5
    Got in about 1/2 gallon. Assuming I have air in it can I drive it or should I idle for a bit?
    Also, driving it for the little that I did wouldn’t hurt anything assuming the gauge didn’t go past where it normally does, correct?
  11. Sep 15, 2021 at 9:05 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    If it didn't overheat you should be OK.
    Dm93 and awoit[QUOTED][OP] like this.
  12. Sep 15, 2021 at 9:06 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If there's no coolant to tell the gauge what temperature the engine is, who knows.
    You should burp it just like the video.
    Dm93 likes this.
  13. Sep 15, 2021 at 9:09 PM
    awoit
    CA
    08 TRD, SR5
    Well the needle moved from when I started to when I killed it, so hopefully there was enough to regulate it. Otherwise I’m not sure how it would’ve stopped where it did, just looking for clarification.
  14. Sep 15, 2021 at 9:17 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    You should really do some research before working on your vehicle again.
  15. Sep 15, 2021 at 9:19 PM
    awoit
    CA
    08 TRD, SR5
    Thanks mom
  16. Sep 15, 2021 at 9:26 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I mean in all fairness, it is the volumetric equivalent of having 9 "extra" bolts when you removed 10 while working on your vehicle and going for a drive. :boink:
    Gr8rSherman8r and Torspd like this.
  17. Sep 15, 2021 at 9:34 PM
    Bloodytaco208
    Bloodytaco208 Well-Known Member
    Twisted steel sex appeal reg cab tacoma
    Bunch of built and bought mods
    Unless you haave a vacuum filler, if not do this.
    Take the cap off when its cold. Fill the radiator till its full. Completely full.
    Put a piece of cardboard in front of the radiator to speed the heating process.
    Youll have to wait let get to operating temp where the needle is in the middle. Make sure it doesnt rise. If does turn it off. Let it run at operating temp for about 20 minutes. This will help any air bubbles be released.Shut it off and let it sit. Let it sit overnight. Then check the coolant in the radiator. Fill it till its full. I believe the capacity is 9.2 quarts, but unless you drained the block as well you probably wont need this much.
  18. Sep 16, 2021 at 2:55 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    You got to be kidding. You couldn't wait until tomorrow to post this?
    winkel likes this.
  19. Sep 16, 2021 at 3:19 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Truth.
    If everybody used the search function first this would be a boring forum.:bananadead:
    cmoore likes this.
  20. Sep 16, 2021 at 5:22 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I may have overlooked it.
    Turn the heater on high and let the coolant circulate through the heater lines and core as well. That will push the air out of those areas as well.
    Tacos4ever15 and davidstacoma like this.
