Drained tranny fluid versus oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kellarm, Jul 29, 2016.
  1. Jul 29, 2016 at 8:59 AM
    kellarm
    kellarm [OP] Well-Known Member
    2002 Tacoma
    Yes, I'm an idiot! Too many Bud Lights! Anyway, was changing oil last night (successful oil change...not hard at all) and initially opened the trannny drain. I left the plug out until nothing was dripping anymore. I then realized what I did, put the plug back in and drained the oil.
    Anyway, hope I don't need to take to dealer. How do I refill?
  2. Jul 29, 2016 at 9:04 AM
    mbarbay
    mbarbay Well-Known Member
    Baton Rouge, LA
    2016 Tacoma BBP DCSB LTD 4X4
  3. Jul 29, 2016 at 9:07 AM
    Rambo MARINE Recon
    Rambo MARINE Recon Well-Known Member
    Robert Goudin
    2013 Toyota Tacoma PreRunner DCLB V6 Auto. Hvy Duty
    Many, suspension, Hood Scoop,Decals and Pin Stripping, New Tires Michelens LTX MS2
    Go to Amsoil site to see capacity of drain and fill,on tranny, my 2013 is 3.2 qts. fill plug is on passenger side near tailstock of tranny, use a WS ATF Fluid, as Amsoil,Valvoline ,Totota OEM WS or others !measure exact as per your specs.
  4. Jul 29, 2016 at 9:21 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Probably did yourself a favor...now the level will be correct.
    Taco Fan, Kilokato, scottalot and 4 others like this.
  5. Jul 29, 2016 at 9:24 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    ^^ Right on, Man. Right on. Now accidentally drain the rear diff. and really see a shit show.
    scottalot likes this.
  6. Jul 29, 2016 at 9:24 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
  7. Jul 29, 2016 at 9:25 AM
    MadisonTaco
    MadisonTaco Well-Known Member
    Madison,WI
    2016 TRD Off-Road DCSB
    Softopper Roof Rack
    How warm was the oil? The transmission needs to be at a specific temp to check oil. If it was to warm you now will be low on oil.
  8. Jul 29, 2016 at 9:35 AM
    kellarm
    2002 Tacoma
    Engine was cold (other than sitting in this Carolina heat), just started it and pulled into garage, shut it off.
    Can I drive the thing to the store for more fluid?
  9. Jul 29, 2016 at 9:39 AM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    How much fluid came out? If you opened the "check" plug instead of the "drain" plug you would not have had much fluid come out. If you opened the drain plug and a lot of fluid came out, I would not drive the truck at all until you re-fill.
    TACO TX likes this.
  10. Jul 29, 2016 at 10:15 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    NO!!!!!
    The hammer likes this.
  11. Jul 29, 2016 at 10:15 AM
    kellarm
    2002 Tacoma
    Check plug, drain plug? Hell if I know. It was on the bottom, looked like the oil drain plug. At least at the time it did :)
    ajm and smitty99 like this.
  12. Jul 29, 2016 at 10:16 AM
    kellarm
    2002 Tacoma
    Well crap, guess ill be driving my old 2002 Tacoma with NO AC up to the autozone. I can use their fluid right?
  13. Jul 29, 2016 at 10:17 AM
    smitty99
    Scottsdale
    Be cautious with what you use. If anything ever happens (issue pops up under warranty on your trans) and they find out somehow that you mucked with the fluid, you could be up shit creek.
    Kilokato and kahanabob like this.
  14. Jul 29, 2016 at 10:19 AM
    MadisonTaco
    Madison,WI
    Softopper Roof Rack
    If the fluid was cold you shouldn't have any run out. On the third gen the check and drain are the same. There is a small tube that is screwed into the drain. That sets the level of the fluid at a specific temp. That is why you cannot check your fluid when it hot or it will be under filled.
  15. Jul 29, 2016 at 10:19 AM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    classic goat rope in progress. now you have to make sure you get the correct tranny fluid from the store. then how much to put in? then getting it in the fill hole on the passenger side of the tranny, will need a pump tool.
  16. Jul 29, 2016 at 10:29 AM
    eon_blue
    Azusa, CA
    OP are you talking about your 2002 Tacoma? Just curious cause that's what it says you have under your avatar but this was posted in the 3rd gen forum. Not a huge deal just want to be sure that you get the right advice on how to proceed, if there's any difference anyway. I thought the 3rd gen transmissions were sealed? :notsure:
  17. Jul 29, 2016 at 10:41 AM
    kellarm
    2002 Tacoma
    No, I was changing the oil in my 2016, my 2002 is what ill be driving to the store to find tranny fluid
    eon_blue[QUOTED] and smitty99 like this.
  18. Jul 29, 2016 at 10:49 AM
    mbarbay
    Baton Rouge, LA
  19. Jul 29, 2016 at 11:00 AM
    kellarm
    2002 Tacoma
  20. Jul 29, 2016 at 11:27 AM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    Read this first! Checking the trans fluid level in the 3rd gen is not the same as in the 2nd.
    The hammer and MadisonTaco like this.
