Drained transmission fluid by accident
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jardoo, Oct 13, 2018.
  1. Oct 13, 2018 at 12:12 PM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
  2. Oct 13, 2018 at 12:16 PM
    henryp
    Henry
    Montana
    Just when you thought your day was bad, there are other people having worse days. Full disclosure, I’ve done a lot of silly things over the years and posted here a few of those mishaps. Good luck OP
    jardoo[OP] likes this.
  3. Oct 13, 2018 at 12:35 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Why not measure what you drained and put that amount back? With fresh fluid of course
    1bad2k and kahanabob like this.
  4. Oct 13, 2018 at 1:13 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Better make it one.
    Six one packs.
  5. Oct 13, 2018 at 1:23 PM
    jardoo
    jardoo [OP] Well-Known Member
    Beirut, Lebanon
    2016 DOUBLE CAB MGM 4X4 TRD OFF ROAD SHORT BED
    Haha
    i dropped the truck off at toyota earlier. They said they MAY be able to have it done by end of the day, but most likely it will be done monday morning.
    247 Dollars to replace the fluid.
  6. Oct 13, 2018 at 1:24 PM
    jardoo
    Beirut, Lebanon
    Oh that sounds amazing!
    ColoradoTJ[QUOTED] likes this.
  7. Oct 13, 2018 at 1:24 PM
    jardoo
    Beirut, Lebanon
    It's a closed system.
  8. Oct 13, 2018 at 1:24 PM
    jardoo
    Beirut, Lebanon
  9. Oct 13, 2018 at 1:25 PM
    jardoo
    Beirut, Lebanon
    yeah im not too happy about that, but i have no choice.
  10. Oct 13, 2018 at 1:30 PM
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    I made the same mistake the first time I changed the oil. I immediately noticed the red fluid and reinserted the plug, only lost a fluid ounce or two.
    Unlike you, I was sober (making matters even more embarrassing)
    I have not made that mistake again!!
  11. Oct 13, 2018 at 1:38 PM
    Hank Heel
    WA
    I don’t understand?
  12. Oct 13, 2018 at 1:39 PM
    jardoo
    Beirut, Lebanon
    toyota told me it was a closed system and i couldnt do it myself. theres no dipstick.
    like it required a pump or something.
  13. Oct 13, 2018 at 1:47 PM
    Hank Heel
    WA
    I’m assuming you drained fluid out the pan only and not the converter, if you measure what you drained, you could safely put back same amount, that’s what the fill plug is there for. How do you think people add fluid to their transmissions that come low from factory? It’s not a “closed” system. Yes it doesn’t have a dipstick, most modern cars don’t, but the drain/fill plug is there for a reason.
  14. Oct 13, 2018 at 1:48 PM
    jardoo
    Beirut, Lebanon
    Ohhhhh i see
    i honestly dont know much. This is my first vehicle that i actually maintain myself. Im learning little by little, though.
    Hank Heel[QUOTED] likes this.
  15. Oct 13, 2018 at 3:55 PM
    #35
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    just measure the amount of fluid that came out and put that same amount back in. there is a fill nut up higher where you add the fluid back in. may need a funnel with a hose to get the fluid in but you can figure it out.
  16. Oct 13, 2018 at 4:09 PM
    #36
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Damn man, next time just measure what came out and put that amount back in. Toyota WS AT fluid is about $7 /qt
    I’d get a pump that screws on top of a qt bottle then you can change your two diffs and Tcase fluids, if not they’ll rape you the same on those
    tcjacado likes this.
  17. Oct 13, 2018 at 4:16 PM
    #37
    jardoo
    Beirut, Lebanon
    man, knowing me, ill probably mess that up.
  18. Oct 13, 2018 at 4:18 PM
    #38
    Grossomotto
    2017 4WDV6LB6MT
    It’s so easy cavemen can do it, proof is many guys here change theirs all the time, including myself
    303tacoma likes this.
  19. Oct 13, 2018 at 4:19 PM
    #39
    tcjacado
    tcjacado Well-Known Member
    Practice on a friend's truck:thumbsup:
    jardoo[QUOTED][OP] likes this.
  20. Oct 13, 2018 at 4:19 PM
    #40
    jardoo
    Beirut, Lebanon
    really? toyota told me they have a special machine that does it. they said you also have to put the correct amount and too much or too little would mess things up.
